Magnavox no video output
Hi, my dvd recorder has stopped playing picture but still has sound. is there anything i can do or do I have to take it to repair shop? thanks.
    Genius:
  • 1,550 Answers
My dear frien do you by mistake activate progresive scan function,if you do it deactivated.Good luck
Posted on Aug 17, 2008
SOURCE:
How to use without remote
UPC 961613194763 053818570722
  • HDMI Output (rear), Remote control, Plays DVD Video, DVD_R/RW (VR format), DVD-R/RW (Video format), CD-R/RW, Audio CD, MP3)
  • MAGNAVOX ZV427MG9 DVD Recorder / VCR Combo LINE-IN RECORDING (NO TUNER)
  • 1080 Up-Conversion, Progressive Scan Video Out
  • Five Speed for up to 6-Hours Recording, Dolby Digital Stream Out
  • 2-Way Dubbing (VCR > DVD, DVD > VCR), Satellite Link Recording, S-Video Input / Output
  • Dec 02, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
    Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
    If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
    There you go..Your TV's video and sound is on the
    DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
    when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
    Take care and please
    Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
    Just purchased this Magnavox DVD/VCR combo (ZV427MG9 A), bought in USA. Plays okay (video and audio) with HDMI output but, plays only video (no audio) with either set of component audio output RCA jacks. ...
    I hope you are connecting 5 RCA jacks when using the component video out. HDMI cable carries both audio and video over one single cable but the component video has 5 jacks, 3 for video ( Red/Blue/Green ) and 2 for audio ( Red/White ).
    Apr 07, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
    Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
    Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
    Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
    Hookup between TV, DVD recorder and VCR is completed.
    Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
    Hope this info will help you.
    Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
    Magnavox DV220mw9 won't record from Tv, hard to connect
    check out this diagram, paying close attention to the audio video cable hookups.
    assume the cable tv box represents the converter box
    you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
    Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
    If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
    You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
    So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
    the tv will have to be set on the line input to view the signal from the dvd vcr combo.
    That is as easy as I can put it. Study the diagram closely. You will see what I mean.
    Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
    Magnavox mwd2205 - VCR Function
    grace0308, Many of the combo units have multiple video outputs and some, like the SVHS and RGB Component outputs, are for DVD only. Make sure that you are plugged into the proper video output. Play a tape and try them all.
    Mar 08, 2008 | Philips Magnavox DVD/VCR Dual Player
    It does not display or play
    You have to run a search of available channels on the DVD recorder through the setup menu. After the recorder has located all available channels, make sure the TV is on the correct input. (Video 1, Video 2 or whatever)
    If all else fails, then read the manual. HaHa
    Dec 29, 2007 | Philips Magnavox MWR10D6 DVD Recorder
    Finalizing DVDs of a previous burner
    Neither will work. you will have to try a computer.
    Oct 28, 2007 | Philips Magnavox MWR10D6 DVD Recorder
    Televison & Video Logo
    52 people viewed this question
    Top Televison & Video Experts
    Ekse
