Question about Saeco Royal Professional Espresso Machine
Magnetic vallve Hey mate, thanks for the info. How do i find out for sure. Is it easy to fix or need to replace ?
  • 515 Answers
If you try to make a cup of water(tea) and you hear the pump start but no water is comming then you have to replace the magnetic valve.
Posted on Aug 17, 2008
Black "blobs" on PC monitor
hey there I think the problem is your magnet. Make sure to never keep magnets near your laptop. A magnet can erase the data off your disk and cause issues with your monitor. Anything that uses electro-magnetism to function will be affected by magnets.
Cheers mate!
Oct 16, 2017 | Dell Computers & Internet
SPACE MATE
please proceed. and fix it. God bless you
Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Mar 29, 2013 | Exercise & Fitness
I have a WF-T556 top loader with a de error. Should there be a magnet on the lid of the machine??
There sure should be....why, because mine stopped working as well. Found magnet inside machine after getting rid of water on spin cycle (thankfully it still allows the water drain to occur). Put magnet back on and hey presto, all good.....if only I had taped it on as 5-6 washes later and it has fallen off and I can't find it - hopefully a standard magnet will be enough to fix from shops - I am sure LG or proper repair place sells them for a fortune :(
Jul 04, 2010 | LG WFT1071TP Top Load Washer
Head bolt torque specs?
I really really really hope you turned the bolts an additional 90 degrees after torquing to 22 Ft-lbs. Otherwise, you may be taking that head off again.
Best of luck,
David
Feb 09, 2010 | 1994 Toyota Celica
My xbox 360 doesn't read games but there is no red ring. it just says open tray even when there is a game already in there
hey mate, i have the same problem, i know how to solve it.. my xbox just got 3 red rings and seeing where i can help myself. But, what u need to do, is when ur disc tray starts to close when there is a game in there, tap on the top of the xbox where the disc is. Dont tap too hard, just when its not working, try a little harder. If u dont believe me, type it in on youtube. Good luck mate :)
Jun 29, 2009 | Microsoft Xbox 360 Console
Desktop icons do not load when pc is restarted - something in the regestry was accidentially deleted. How can this be fixed? System restore didn't work. Thanks!
mate I had the exact same problem as you on one of my mates pc's but i managed to get it fixed.
It was due to a virus which was hidden really well away in the system folder. I suded AVG Anti Virusmag-glass_10x10.gif, Spybot Search and Destroy and also Ad Aware.. which found the file.. and quarantined it.. then I just deleted the file thru explorer.. and ran these three again .... then restarted and hey presto all was ok !
My mate already had AV Software on his machine - he just hadnt updated it hence why this one got in, which effects the log in process.
hope this helps
May 28, 2009 | Computers & Internet
Speaker was dropped - Tweeter Magnet came off - looks to have been glued on by manufacturer. What type of glue should I use? JBL EON 15 Thanks
Clean the mating surfaces very well, mark on the side of the magnet (arrow or dot) which surface of the magnet was glued (shouldn't make a bit of difference, I'm just a little anal) and then use any brand of quick setting 'super glue.' This glue will not only hold well but will also introduce the thinnest film between the magnet and 'keeper.' Too much space between mating surfaces can weaken the field and reduce the efficiency causing an imbalance in volume relative to the other tweeter. If anything else is loose, the tweeter is junk because any shift of the voice coil will cause the speaker to distort or rattle.
If you need to replace any speaker ever, replace both channels or have possibly lousy matching between channels.
Apr 24, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Can't find thermostat on 1994 olds cutlas sierra ,how do i change
judy-make sure the car is cool and follow the upper radiator hose to the engine.the thermostat should be located under a housing @the motor. remove the clamp,pull the hose off,remove two(usually bolts and pry housing off motor careful not to scratch mating surfaces. clean mating surfaces well and apply sealant to bothsides of gasket-should come w/thermostat.make sure thermostat is pointing correct way(box should tell you)askcounter guy @auto store for correct sealant tighten bolts-add alittle premixed antifreeze(depending where the hose is @ it may leak when you pull the hose.I know this is alot of info but hey you asked..buy a chilton repair manual to help with projects like this..Good luck
Jan 20, 2009 | 1990 Oldsmobile Cutlass Ciera
My w350i
evry1. i also have the same problem with my W350i. As i enjoy fixing stuff i found while playin around with the flip that there is ment 2 be a little rectangular magnet which fits into one of the grooves on the flip. i know this is the soloution for sure as my friend also has the W350i, from which i compared the flip to my phone. i used his small magnet thingy and put it in the groove on the flip and put it back with my 4one. it then worked as normal. i had probably lost mine somewher:S. but that was my mates magnet so i returned it, i still need to find out where to purchase this small magnet product.
Oct 29, 2008 | Sony Ericsson W350i Cell Phone
Thanks
Hey no worries mate... did you get the other post. We can keep working from there :)
Apr 21, 2008 | Audio Players & Recorders
Saeco Royal Professional Espresso Machine Logo
56 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
