Question about PSB Image 4T Speaker
Defect woofers My PSB Image 4T lodspeakers have 3 defect 5-1/4" rubber-surround woofers. Just 1 of the 4 woofers is ok. Is it possible to buy 3 woofers? Where? Regards, TN.
    Problem Solver:
  • 5 Answers
I'm from Indonesia.
If I had problem like you, then I would have bought 2 pairs of image 1B, then just take out the midbass and replace to 4T as they are same, cause expensive to order only the midbass from out of country.
Cheers,
Posted on Jul 29, 2009
    Problem Solver:
  • 14 Answers
If you can get the same woofers, then yes you should be OK, pull the units, get the part number off the back and then try Google for a source.
If you can't find a exact replacement then you are looking at replacing all of the woofers, rule of thumb is that you do not want to mix speakers, you end up having one speaker sounding different than the other, so what ever you do to one, you need to do to the other. In that way what tonal changes that happen will happen to both speakers and they remain matched.
Now if you need to find replacements, you need to replace with like impedance speakers, and try to find a speaker very similar to what you are replacing. Just don't throw anything in the cabinet, if the impedance isn't correct not only the sound could be bad, but you could also damage your Amp or Receiver.
john
Posted on Aug 20, 2008
I have AIWA NSX-RV85. The sub-woofer surround tore leaving just the cone. When I play, The woofer just makes a rattling sound coming out of vibrating cone.Any advise on how to fix my speakers.Thanks
Refit the rubber, you can find itbon eBay, its called reconing actually in this case the cone is the inlybpart wich you dont want to replace... The rattling is beingproducer due to the fact the rubber normally holds the cone ibto positionering over the coils. This rattling is not good can defect your cone. So dont play it roll you got a new rubber fitted!
Nov 08, 2016 | Aiwa Audio Players & Recorders
What is the possible defect of sanyo tv,standby power only
Here's what i think the problem is. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Televison & Video
I ball 5.1 sound driver
your driver can play 5+1 but you will have to get a way to make the input in the woofer in a single jack ...The issue is that the 3 way that normally is the input in a perfect surround..is not available in a laptop cause only have one exit jack for a stereo out ...if in a desktop you have 3 jacks in the back at least ..and from the driver you can change the values in %+1 and this way you will have the woofer with central ..the front and the rear ..this one is not possible ...the only way is to select the cd in ...in the amplifier of the woofer ..(ou other stereo simple in ) and use a single jack ..but this way you will have exit to all the speakers ..it will not be a perfect surround but will be a good stereo ...and the difference is not that bad...
Another solution si to get a adapter wit a jack and 3 out in which to adapt the normal 3 wires that makes the input signal for the surround ..and is the closest to surround that you can get ..
Jun 27, 2010 | Lenovo 3000 Y410 Notebook
My tv does not show any image and shuts off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
Hope this helps
May 21, 2010 | Akai LCT3785TA 37 in. LCD HDTV
Humming noise when woofer turned on
check the NPN and PNP transistor output maybe shorted.....
Jul 07, 2009 | PSB Image Sub Sonic 6i Subwoofer
I have three horizontal lines across the printed document
Here is the print defect information from the service manual.
1. Toner Cartridge.
The circumference of the photoconductive drum is 3.75 inches (94mm). The circumference of the developer roller is 2 inches (51mm). If a defect appears in the print image at these intervals, assume the defect is associated with the Toner Cartridge. Replace the Toner Cartridge.
2. Fuser Assembly.
The Fuser Roller’s circumference is approximately 2.5 inches (63mm) for the LJ4, and 3-1/8 (79mm) for the LJ4+/5. If a defect
appears at this interval, assume the defect is associated with the Fuser Assembly. Clean the Fuser Assembly rollers. Replace the assembly if necessary.
3. Dirty Roller.
Any dirty roller along the paper path may result in a pattern of
repetitive print image defects. Examine and clean rollers along the
paper path.
We have the full service manual download available for $6.95 if you need it. We also carry all repair parts for your printer.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jun 29, 2009 | HP LaserJet 4 plus Printer
KDF46E2000
Solutions?
Hope this helps
Aug 12, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Logitech X-240 woofer
you should google it and find a woofer of the correct size with at least 8 ohms to be safe. (more ohms= less risk of fire!) good luck!
Jul 26, 2008 | Logitech X-240 Computer Speakers
Repeating defects appearing on every 3rd page
That most likely is on the transfer belt assembly, You can look at that belt and see if the defect is a mark that may be cleanable or actual damage to the transfer belt, which would require replacing the transfer belt.
Jun 02, 2008 | Xerox Phaser 6200DP Laser Printer
PSB Image 4T Speaker Logo
270 people viewed this question
Top PSB Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Terry Weaver
Terry Weaver
Are you a PSB Audio Player and Recorder Expert? Answer questions, earn points and help others
