Question about Samsung CLP 300 Laser Printer
Error #12288 Hi I have been using my printer for 6 months with no problems - Now, the printer started stalling alot - and used to take very long to print. 3 days ago it stopped printing altogether - I get a error #12288 message then it says "unable to create temp file" when i click ok it says "color matching module error" Please help Naseeba
  • Anonymous Aug 23, 2008
    my hp has been working fine for a year now any time I try and print I get error 12288 and a color matching error and the printer that is a samsung clx 3160 prints out a blank page.
  • Anonymous Sep 06, 2008
    I got the same problem. My CLP-300 is connected to an XP, and it prints fine locally. However, when my Vista machine tries to print on it remotely, it gave me that #12288 error. Any help would be appreciated.
  • 4 Answers
Problem in the driver call to the toll free no 1800110011 and ask for the resolution.....
Posted on Aug 31, 2008
SOURCE:
How to fix sanli whipper snipper start pull problem?
Hi, You should replace the spark plug. Most plugs die after 6 months of use. Also make sure that fuel mix is correct. Too much oil will make the motor run poor and stall. Good luck.
Aug 13, 2014 | Garden
Error Code E000014-0001
are you sure this is the exact error message
Click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files?
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
you could run the check disk utility
click start?run type?cmd then type?chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen when you restart your computer then defragment your hard drive
another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while chkdsk is in process any input may damage your computer
or you might download and use this registry cleaner it is totally free to use
?http://download.cnet.com/ccleaner/
hope this helps
Jun 26, 2011 | Computers & Internet
Canon d420 error code e000
are you sure its a motherboard error
hope this helps
Jun 25, 2011 | Computers & Internet
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Red light flashing 6 times
Hi my name is Roety,
I can help you with your issue ,
6 Blinks is a bad Y buffer Board error code.
You can check for bad capacitors , but most likey will need the Y sus main, Y upper and Y lower buffers replaced .
Tech labot is about $250 plus parts about $600
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
HP error code 0xc18a0001 on my HP C7280 all in one printer. I am using non HP inks and have just filled all of them up and reset the printer chips. I have been trying to fix this problem for 6 months now...
That is an ink system failure code.
This happens alot using refillable and reset cartridges.
Try this..
1) unplug power
2) hold the power button and reinsert power cord
3) let the printer boot up
4) try it...if it works fixed.
Also HP has some special firmware upgrades available if you get hold of them by email or chat.
Also...don't tell them your using Non-HP ink, or they will drop your call like a hot potatoe.
You might try some HP inks and see if the cartridge change to HP works.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 13, 2009 | HP PhotoSmart 1215 InkJet Printer
Image source 50 code E64
E064 Error code details Power supply voltage error (high-voltage error)
0000 The presence of a high-voltage error is communicated by the composite power supply PCB.
(The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
Main cause
 The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
 Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
 YES: Clean the contact, and set it once again.
2. Wiring
 Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
 a. DC controller PCB (J301) <-> composite power supply PCB (J136)
 b. composite power supply PCB (J130-7) <-> primary charging roller contact
 c. composite power supply PCB (J130-1) <-> developing assembly contact
 d. composite power supply PCB (FT133) <-> transfer roller contact
 NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
 Try replacing the composite power supply PCB. Is the problem corrected?
 YES: Yes.
 NO: Replace the DC controller PCB. pls rate for my good deed!!!!!!!!Good Luck
Sep 21, 2009 | Office Equipment & Supplies
System Error E000 and E003
E002 Error code details Heater temperature error (fails to reachspecific level; inadequate increase)
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Action
 See the description for E003. E003 Error code details Heater temperature error (abnormal drop; low-temperature detection)
0000 The main thermistor reading is lower than 140°C when paper is moved.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
Action
1. State
 Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate?
 NO: See "The fixing heater fails to operate."
2. Wiring
 Is the wiring from the DC controller PCB to the fixing film unit normal?
 NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
 Try replacing the fixing film unit. Is the problem corrected?
 YES: End.
Jul 28, 2009 | Canon imageRUNNER 2000 Copier
Lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
To check the cartridge carrier:
1. Unplug the printer.
2. Move the cartridges to the left by hand and then take them out.
3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
1. Remove any other devices attached to the USB/LPT port.
2. Uninstall the Lexmark printer.
3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
4. Reinstall the printer.
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Machine error 41
GO TO fixyourownprinter.com/forums/printer/22036 the solution has kept mine running another 6 months.
Dec 20, 2006 | Brother MFC 5100c InkJet Printer
Samsung CLP 300 Laser Printer Logo
149 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
