Question about BenQ FP71G 17" LCD Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
When switched ON, it display the Benq logo then display the normal display output from the computer. Then it turns dark with power LED still green, then NO light on the power LED & later it come back and the display show the Benq logo (as if we switched the power OFF & ON again). This sequence just repeat & the time between is not constant (it varies). Sometime a few seconds & sometime about 30 seconds in certain steps.
Best Regards,
Simon Tukina (
  • 220 Answers
Seems either aproblem with Invertor board or Front panel switches are leaky.
Posted on Sep 12, 2008
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
The monitor screen goes dark about 10 minutes
Please verify the power option setting present in 'control pannel' option once. If you have selected to turn off the power supply after 10mins, (once the system is in idle state) then the SMPS will stop supplying power.
Jul 20, 2009 | BenQ FP71G 17" LCD Monitor
No audio, no indicators but blinking green LED by power switch.
Replace elco C61 (68uF/450V) ; it is empty or almost empty.
Also remove the dark-brown glue carefully. The glue turns from light to dark brown by heat and becomes conductive (some Mohms)
Jun 25, 2009 | Creative Labs Gigaworks S750 Computer...
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Power but no picture
Try to re-solder the inverter part of the board. You may recognize that part where the 4 connectors from the backlight tubes can be found.... usually the small transformators (sorry, my technical English is not good) have bad soldering eyes after longer use. This may work if backlight turns on for a few seconds, then the power led is still alight but screen goes dark.... the inverter then "thinks" one of the tubes might be defective and turns power off. Hope this helps a little...
Jun 20, 2008 | BenQ FP71E 17" LCD Monitor
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here
Jun 03, 2008 | BenQ T705 17" LCD Monitor
Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Aug 15, 2007 | BenQ FP737S-D 17" LCD Monitor
Blank scren, led stays green for only one second
Explicit enough to see that's this a a repair shop job. That also probably means a replacement- cost of which will not be much more than repair prices. One thing how ever- the power supply[which would appear to be the problem] is this built into the screen [that is does the screen have mains power direct? Or is it powered from an external 'Power Brick' If it is of the Power Brick type - then a new power supply is the answer - get on of the stabilized universal type with a fistful of connectors and a voltage selector switch.
May 24, 2007 | BenQ FP737S-D 17" LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
436 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
