I am unable to get a picture when I connect the AV Cable supplied with the Nikkai 8.5 Inch LCD Colour Analogue/Digital Widescreen TV to watch DVD, I can hear the DVD but no picture. I also have a 7"Maxim Colour LCD Analogue TV and I have no problem getting a picture or hearing the DVD. Please can you help?
  • fbazthecat Aug 24, 2008
    Thanks, but it did not help, I probably will have to send it back to the supplier because it maybe defective. I tried different cables, but nothing worked. My 7" Maxim worked perfectly with different DVD players.
    Thanks again.
    Genius:
  • 1,011 Answers
Dear,
check the correct connection of AV cable..
or maybe its defective..try with another one..
regards,
Posted on Aug 17, 2008
  • SALMAN NASEER Aug 24, 2008
    dear,
    here u described before that u have connected ur other tv with the save dvd and u can hear both sound and vedio.
    does it mean what i supposed.
    moreover, have u checked it with this same cable.
    kindly brief it.
    regards,
Philips quadrasurf TV
Analogue TV reception has nothing to do with signals from Blu-ray players.
Connect your Blu-ray player to either a HDMI port on the TV, or use a HDMI to DVI adapter (which is picture only) and supplement it with a a connection for audio via RCA/phono- or RCA/phono to jack cable from the BD player to the TV.
Press the AV Input button on the remote to cycle through the input sockets.
Sep 08, 2014 | Philips 40MF430B/F7 model Magnavox LCD TV,...
The picture doesn't hold. The picture shows just snow on the tv.
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Aug 25, 2014 | Televison & Video
Does anyone know if the L37G10A supports PAL I as well as PAL B/G. I'm moving from Australia to UK and am wondering whether to bring the TV
Screen Type LCD Panel Type IPS-alpha Progressive Full-HD LCD Panel Panel Aspect Ratio 16:9 (Widescreen) Aspect Ratio Control Modes (TV/AV modes) 4:3, 14:9, 16:9, Just, Zoom1, Zoom2, Zoom3, DTV: 16:9 & 4:3 Full Aspect Ratio Control Modes (PC mode) 16:9, 4:3 Comb Filter Yes Progressive Scan Yes TV Tuner Receiving System DVB (Digital), PAL-B/G (Analogue) Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G
Contrast Ratio 1 - Dynamic: 20000 Picture Adjustment Modes / Film Modes Normal, Dynamic, Cinema, Eco Colour Temperature Control Cool, Standard, Warm
May 21, 2011 | Televison & Video
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
Following the beginning of digital switchover, pressing the menu button only comes up with 'picture quality' and is unable to access 'installation'.
If your TV is not in Digital it won't give you the tuning option.
Select DTV from the on screen menu, (like scart 1 scart 2 etc). When you have found DTV select it and then press menu for tuning.
Hope that helps.
Mar 30, 2011 | Televison & Video
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
Tv works but picture is showing in blue
If the picture is blue only and there is no red or green, you have either colour gun failures or if you are trying to watch a picture from a component source there maybe something wrong with the red and green cable feeds. Try watching a DVD using a single composite video feed (usually a yellow RCA plug). If this unit has an internal tuner (either analogue or digital) and you still only see blue broadcasts then you have a problem. Whether this unit is an LCD or CRT rear projection TV the repairs will probably be expensive. Ultimately, it is not a user repairable device and needs a qualified Sony tech to undertake the work.
Sep 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
TELEVISION
This user manual should help!
http://portablemedia.manualsonline.com/manuals/mfg/wharfedale_international/l15t11wa_l15t11wc_l19t11wa_l19t11wc_l20t11wa_l20t11wc_l19t12wa_l19t12wc_l20t12wa_l20t12wc_l22t11wa_l22t11wc.html
Jan 13, 2008 | Televison & Video
Televison & Video Logo
233 people viewed this question
Top Televison & Video Experts
