Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Rear projection tv
I think my focus board is going out xause wen i turn it on everytime an image that has blue in it will have a shadow.
    Scholar:
  • 167 Answers
Hello. well that's not from your focus board.!!! tv's don't have focus board's .!!! they have focus pod's.!!! it's a small black box with nob's that can be turned to ajust the focus.!!! so the tv look's clear.!!! the problem you have is in your ( blue IC chip') . it's going bad and will need to be replaced.!!! there are 2 (IC chip's) there is one for the red & one for the blue.!!! and they are on the convergence board.!!! they will have letter & number's on them.!!! like (STK 1140 or STK1158) NOW.!!! UNDERSTAND THAT THESE AND NOT YOUR NUMBER ON YOUR SET.!!! YOU WILL HAVE TO LOOK FOR YOUR SELF.!!! ON THE CONVERGENCE BOARD TO FIND OUT WHAT number's are on your (ICchip's) .!!! and replace them .!!! and that should fix your problem.!! hope this help's you.!!! "GOOD LUCK"
Posted on Aug 18, 2008
I recently bought a samsung hcn4226w at a yard sale for $50. Thought it was a good deal, but when i got home I saw the picture had a double image and the picture doesn't seem bright. After some tinkering...
This tv have convergence problems.Ur tv convergence board the 2 STK convergence ICS are defective,and some or all it resistor are dead.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.Spend about $100 dollars more this tv can be save.
May 14, 2010 | Samsung HCN4226W 42" Rear Projection...
I have an akai rear projection big screen tv that has blue shadows on everything. When the auto focus turns on, about half way through the process, everything clears up. When the auto focus completes, the...
Replace the Blue convergence IC, But you should consider replacing both of them, because if one has failed then the other is likely to sooner or later. They are large Black IC's mounted on a Metel Heatsink. I believe on this model the board is in the middle of the unit. Before you replace check the solder connection on the Ic's first you might just have a few cold solder joints, if not then replace both IC's
Nov 09, 2009 | Akai PTH5498 54" Rear Projection...
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Blue convergence
SINCE YOU HAVE REPLACED THE CIRCUIT BOARD,THE NEXT STEP WOULD BE CHECKING VOLTAGES GOING TO THE CONV. BOARD COMING FROM THE POWER SUPPLY CIR. BOARD.....IF NO VOLTAGE METER,,SOMETIMES, THERE ARE FUSES ON THE POWER SUPPLY CIRCUIT BOARD THAT SUPPLY THE NEEDED VOLTAGES FOR THE NEW BOARD YOU JUST REPALCED...UNPLUG THE SET,,CHECK FOR A BLOWN FUSE----I THINK THERE IS 2 OF THEM--ONE FOR A NEGATIVE VOLTAGE AND ONE FOR A POSTIVE VOLTAGE FOR THE CONVERGENCE BOARD..GOOD LUCK--SORRY, MIGHT NEED A TECH...TUNICA
Oct 30, 2008 | Samsung HCN653W 65" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Toshiba 42PW33Q rear projection gone blue
OK to help assist everyone having the BLUE HUE and CURVED LINES Issue on their Rear Projection HDTV no matter their model. Here are the steps to take. The first thing to check is the FOCUS BLOCK or G2 Focus Transformer or CRX F-Pack. I have replaced mine, however it didn't resolve the issue. I am onto the next item the CRT Board for Blue (Which is the board under one of the three color lamps inside your tv) Please see photo below (if photo is not large enough below go to link to review notes as well) If the CRT Board is not it, then the next step will be the Signal Board which is a larger board in the back. In a week I will have a picture of both.
INSTRUCTIONS:
  1. Remove the outside cover
  2. Remove the wood plank/panel
  3. In the front is the G2 Focus Block/Transformer, while set is on turn the top 3 knobs till the screen goes black/dark grey.
  4. adjusting the colors till you receive the desired or normal color/picture.
  5. Once you have received the proper color/picture tap the side of the Focus Block.
  6. IF The colors go out of wack again and the blue comes back strong then this "CAN BE" the Focus Block.
  7. NOTE: IF the color stays stable, then you problem is resolved and you do not need to replace it.
Replace the G2 Focus Block aka Focus Transformer, if Hitachi it's called a CRX F-Pack. This item will cost about $50. Not expensive. You will likely need a soldiering iron. DO TURN OFF & UNPLUG THE TV WHEN INSERTING ANY METAL OBJECTS INTO THE TV!!
FOLLOW THE PHOTOS/DIAGRAM in link below for assistance in the above instructions. I will post my next process since it was not my Focus Block that was an issue.
ONE SOLID PHOTO Go to URL CLICK HERE, click on that image to enlarge. Hope this helps you all out!
Nov 18, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
