Question about Toshiba e-Studio163 Copier
USB port I downloaded the drivers but still have problem! I instal the e-studio printer in com1 but it does not work. it says that it cannot communicate with the coppier. please help me!
    Genius:
  • 1,447 Answers
Hi-
Make sure you are using a direct cable, not an adapter( usb to serial or vice versa) if you are using a serial cable, make sure your printer is the only one using the com1 port, this should be free...
check and go to command prompt- click on start then on RUN put in cmd then press enter, on black window type dir >com1 then press enter. it should print if its free. other wise go to device manager, delete com1 or uninstall then reboot computer so that it will reinstall the com1 driver back to computer.
keep me posted
Posted on Aug 17, 2008
TSP 700 printer on 32 bit windows 7. It doesn't stop printing and the paper just keep coming out. I've tried to reinstall driver and swapped the printer with the same model with another comput
Check if interface at the back of printer is interchangeable to the type of port your computer will support it. Direct USB to USB or direct connection is recommended to avoid future issues.
Oct 04, 2012 | Star Manufacturing Star TSP700 Receipt...
Can't communicate on the COM1 port
Is this a printer you have installed and are trying to print to it? Maybe you don't have the printer configured properly. More than likely you should be using a usb port instead of a com1 port if it is a printer. Open your printer and check the properties.
Modems also use com ports, so check your setup if you are using a modem.
Jun 06, 2012 | IBM ThinkPad A31 Notebook
I have an old serial printer that works fine, I can not connect it to my new computer via a parallel to usb cable convertor on windows 7!
Hi craig931, First try downloading the latest driver of your printer and your usb converter compatible for windows 7. Second Checked your device manager if your printer and usb to parallel driver properly installed, it should be there. If not yet installed try using different usb port one at a time until the cable have been detected. Third if you see already the printer port force to change it to USB001 or Com1, then try to print. regards,
Sep 26, 2011 | Office Equipment & Supplies
Hi, I have Olivetti PR2E. Now i am using notebook, so there is no serial port at my notebook. Then i bought the usb to serial port cable. I add printer (Generic/text) cannot printing out. then i install...
Hi, what your system detecting is that the PR2E still in COM1 or COM2, if you have the driver installer set the port to USB so that the system will detect your printer via USB. Or change the port access from COM1 to virtual USB.
Jun 22, 2011 | Office Equipment & Supplies
I have the same printer, and xp on my pc, but how do i connect them? my laptop does not have a serial conection. i tried to use a usb/serial converter and i installed the xp driver from minolta website,...
You need to make sure you have selected the correct COM port whin you try to print. Depending on the type of USB to serial converter, the COM port it assigns can change just by moving it to another USB port. Right-click on My Computer and select MANAGE. Select Device Manager from the list. Click on the (+) next to PORTS and double-click on your USB-SERIAL device COM port. Somewhere in the Properties window you should be able to see the assigned COM port (COM1, COM2, etc.). If possible, set the COM port to COM1 or COM2 for greatest compatibility with older software. Then when you print, make sure your printer driver is also set to the same COM port.
Mar 05, 2011 | Office Equipment & Supplies
Toshiba e studio 166 like printer dont work
connect the copier to computer through USB cable, turn it on, then re-install software it will recongnize the port and machine itself.
Nov 01, 2008 | Toshiba e-Studio 161 Copier Copier
E-studio 163 coppier - I cannot connect it to pc
hi frnd do one thing
go to printers and faxes
select toshiba e-163,
right click
select properties
select port
select com 3
try to give print
OR
select com 4
and give print i may be ok.
pls up date me
regards
san
Aug 17, 2008 | Toshiba e-Studio163 Copier
ERR: C2 driver
Hi-
Look for an executable file on that folder and try to install usb driver
Print with usb cable
hi-
when you install the driver, don't connect printer yet to pc. wait for a prompt for you plug in the USB cable so that it will create its own usb vitual printer port, so you mean when you go to printers and faxes, right click on your printer and go to properties then ports, which port has a check mark? it should be usb001 or something then usb virtual printer port.
Toshiba e studio 163 drivers for XP
Try looking here:
http://www.eid.toshiba.com.au/
You need to know if it uses the GDI print system or the optional print board.
Browse the driver section and you should get there.
Nov 12, 2007 | Toshiba e-Studio163 Copier
Toshiba e-Studio163 Copier Logo
202 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
