Question about Panasonic SC-AK330 Shelf System
Radio my unit comes on then flashes f6 and stays there can,t shut it of doe,s nothing after that . what do,es f6 mean we had a bad lightning storm but we have a surge protecter
  • roger6065 Aug 18, 2008
    it,s the f6 not f61
    Genius:
  • Panasonic Master
  • 1,550 Answers
It is f6 or F61 if it´s F61 the audio amplifier IC are damaged and need to be replaced.Good luck
Posted on Aug 17, 2008
What does it mean when one reads FD in the panel and the lights on the panel aren't stable?
The control board to your range may have been damaged because of the lightning storm. It happens when lightning strikes a power line and sends a surge of power to your home. This large current surge can easily damage electronic circuits. More often than not if a device is on and lightning strikes, that is when the device gets damaged. During large lightning storms it is best to turn off all electronic devices. The electricity going to your house is fine now and that is probably what your electrician checked.
Nov 22, 2017 | Kitchen Ranges
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
Why lights won't turn off after a lightning storm last night?
The light switch is defective replacing the switch should solve the issue.
Aug 09, 2012 | Televison & Video
Garage door does operate at all. The lights don't come on and the motor doesn't operate. The "learn" button/diagnostic LED flashes are inconsistent. The number of flashes varies and...
If these problems started immediately after a lightning storm, the printed circuit board is probably damaged. Contact a garage door service company (check the phonebook) for diagnostic support.
Dec 01, 2017 | liftmaster Garage Door 1/2 Hp
After a thunder storm my roof mounted Carrier cooling/heating unit stopped working and now does nothing. Changed the time delay fuses and checked the circuit breakers and they seem fine. Is there a reset...
You may have a circuit board problem. Make sure you have power to the unit first. If you can, get on the roof take the access panel off to the electrical components. Most carrier circ boards have a flashing light display on the board itself. On the back of the panel you just took off should be a kiosk that tells you what the flashing means. If the light is dead, no color but you are sure there is power to the unit, the board is bad or there could be a fuse blown on the board. Most circ board fuses are a small 3 or 5 amp blade fuse mounted right on the circ board. I have seen many a carrier board burn out because of lightning. I hope this is not the case for you, as carrier boards are just a little expensive. Hope this helps you get some air back. Mark
Aug 01, 2011 | Heating & Cooling
I have a 47 inch sanyo. model# dp46848. A transformer blew in a lightning storm and now the tv will not power on. The power light will come on for 5-10 seconds and then shut off. The tv was on a surge...
But, was the cable/satellite feed protected? Lightning can come in from anywhere, not just the power line. The bad thing about the way cable and satellite installers ground things is, they ground to the same grounding system that the house does, which can backfeed the surge through the entire house - it shouldn't, but it can.
I would, however, contact the maker of the surge strip and attempt to file a damage claim. They all come with a liability warranty of some sort.
Jul 06, 2011 | Sanyo DP46848 LCD TV
Central air conditioner unit comprssor doesn't come on i suspect a lightening storm did something while we were away
check main power breaker, and reset breaker on unit, otherwise lightning storm would have nothing to do with units problem other then power surge, which would trip a breaker. Hope this helps, Thanks Mikemc1bean.jpeg
Jun 23, 2011 | LG Heat cool Window Air Conditioner
WE HAD A LIGHTNING STORM AND NOW MY STOVE DOES NOT WORK . EVERYTIME I TURN THE STOVE ON IT FLIPS THE CIRCUT BREAKER OFF.
you mean anything you turn on trips the breaker or just certain items,if so remove rear cover after unplugging unit or shutting off breaker, and look for what is called a m.o.v.(metal oxide varistor) its in there in case of a surge from lightning and has probably shorted(check w/ohmmeter) it protects the electronics side 120volt,but will drop out both legs of power on a tandem pole 120/120 volt breaker because of the way breaker is designed
Jul 08, 2009 | Kitchen Ranges
Bad Storm, Jeep stopped running
It sounds like your problem is in the ignition. Maybe you are using a valet key or your ignition switch has failed. Often when a security light comes on it is because your ignition is not getting the electronic signal needed from the key(coded) to start the car. When your ignition does not recognize the key it shuts off all fuel systems but starter still goes.
Jun 18, 2009 | 2000 Jeep Grand Cherokee
Panasonic SC-AK330 Shelf System Logo
143 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
