Mitsubishi big screen model VS 60601 convergence adjustment
Comvergence needs to be aligned .
  • Anonymous Jan 07, 2009
    I am able to tune in my convergence horizontally in the menu settings, but not vertically.
    sucks
  • 8,617 Answers
You need new convergence ICs. If you can respond to this same post and verify the model number of your mitsubishi, I wll post the correct ICs that your model needs.
Posted on Aug 17, 2008
Where is the Convergence IC on my Mitsubishi VS-60601 1997 Serial #104094. You told me what the problem was with my TV and showed me what a Convergence IC looks like, but now that the projector TV is...
Convergence IC will be mounted on a big Aluinuim Heat Sink They are Big Black ICs and will have Parts # on Them example STK392-570 There is 2 of them together.
Mats Electronics has them 1-800-628-1118
Nov 04, 2010 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS-60601 has a distorted picture with double vision even if it's a DVD playing. The sides of the screen get narrower in the center of the sides when it's turned on. I'm mechanically inclined and...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 19, 2009 | Mitsubishi VS-60601 60" Rear Projection...
Convergence Problem
Unfortunately you will have to replace the convergence board in this unit. it has failed. this particular board regulates the alignment procedure that you are having issues with. replacing this board will fix this issue.
May 21, 2009 | Mitsubishi VS-5047 50" Rear Projection...
Convergence problem
YES YOU CAN DO IT MANUALLY WITH THE SCR,IF IT WERE ME ID TRY DOING IT.THE FRONT SPEAKER GRILL COMES OFF,YOU CAN GO FROM THEREEWS,BUT YOU MAY SCREW IT UP MORE THAN BEFORE
May 21, 2009 | Mitsubishi VS-45609 TV
Convergence problem
I have a VS-45607 and If the VS-5052 has the same menus then there are two options for convergence. One is the basic convergence where there is one set of crosshairs and you line them up. Then there should be an option for "advanced" calibration where the whole screen looks like a grid and you go to un-converged crosshairs and align the screen. Most likely not all of them will need to be adjusted, but for me, the lower right hand corner wasn't aligned right and this cleared it right up.Good luck
Dec 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Red and Blue convergence
you may need a new convergence board only a tv shop can tell you for sure
Nov 03, 2008 | Televison & Video
Mitsubishi 290p080020 big screen tv
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 30, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubushi Big Screen TV Screen Protector vs 60601
that will have to be a dealer orderd item.. Unless you can find one used. I would try the tv shops in your area , they may have a used mitsubishi screen
Jan 21, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS 60601 picture
You need to change the convergence IC's my friend. If you know how to solder and work on printed circuit boards, this is an easy repair, BUT if you have no experience, play it safe and let a pro do this repair for you. Good Luck
Aug 11, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS-60601 60 in. Rear Projection Television Concave
You have a convergence problem my friend. Theres nothing as an alighnment or adjustment you can do unfortanatly as there are no user serviceable parts in these sets unless your a tech and know your way around a projection tv as there is alot of voltage inside these puppys when its off. But Its most likly the Main convergence driver IC's and most repair such as this require alighnment afterwords as well so the average reapir cost on a set with this problem would be about 250 to 400.00 depending on if theres any other componets that fail at the same tim?? Sorry couldnt assitya more But if you need to contact the main company at this addy CustomerCare@meus.mea.com and see if they can direct you to a reliable servicer. Good Luck
Jun 06, 2006 | Mitsubishi VS-60601 60" Rear Projection...
Televison & Video Logo
311 people viewed this question
Top Televison & Video Experts
Electro Med Services...
