Question about Daewoo FR-147RV
Fridge making a loud vibrating noise
I live in a one room apartment and can't get away from the noise! Please help me either try fix it or find a repairman in my area. English-speaker living in Korea so it's doubly difficult to find help. The model is FR-B302ET.
Thank you!
Why does my engel MT45F-U1 fridge and freezer vibrate and make so much noise?
have u checked the groumets on the compressor? more than like are bad
Apr 20, 2015 | Engel Refrigerators
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
Sep 16, 2013 | Refrigerators
Emerson EWC20D3 20 in. TV/DVD Combo what is that loud whining noise from the back
What happens in this case is a small transformer or the high voltage transformer vibrate hard enough to make that sound--not loose or bad but can cause the vibration.
I have seen in customer's homes where it was loud enough to chase cats right out of the room even in a large room.
Two ways to deal with this----with the set apart locate the part by ear or even probing with a plastic tool---when you press close to it, the sound will diminish or go away.
Believe it or not (in our shop) once located we use a hot glue gun to take the sound away---
usually if very loud it is the high voltage transformer on the main TV board (see photo of a typical one) not on the black part but on the iron like (it is a different material) core that looks like a U bolt.
it can irritate but poses no danger.
Mar 28, 2012 | Emerson EWC20D3 20 in. TV/DVD Combo
I have an old Frigidaire refrigeator/freezer, freezer on top. Model # FRT18TJHWO. It say manufactured 06-00. I presume that means June of 2000. I have had this for almost two years. A friend gave it...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 21, 2010 | Frigidaire Refrigerators
Hi my fridge is making a noise, like thunder..rumgling kinda noise ?? help !!
If your fridge is otherswise working fine with the cooling then the fault could be that the compresor mountings have good loose or softened. So If so please move your fridge away to get access and check for the compressor mounting by holding it slighty , itmust be a little firm . If not try to see the rubber mounting bushes at the bottom tighten the botks or change the bushes with the correct type.The second possible fault will be that the fridge is vibrating due to the compressor vibration transfering to the grills, the plastic body,. Look out for loose parts, plastic flaps that cover the bottom or the water drainer that must be out of alignment. Use good double side sticker foam type to fix the gaps and the vibration.I am sure this must solve the issue. Hope you try. Good day.
Aug 14, 2010 | Fisher and Paykel Active Smart E522B...
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
GE top freezer refrigerator: motor has become very loud and refrigerator vibrates. However, when I move the cold control to a lower number, it gets slightly quieter and vibrates slightly less.
Please make sure it is level, the compressor is designed to run on level ground. Also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise.
Find out where the noise is loudest. if it's under the fridge, it's the compressor.You have to check the coil for the compressor and if it's inside the freezer, it's the fan bearing.
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Oct 20, 2009 | Refrigerators
Refrigerator runs way too much.
make sure it is level. the compressor is designed to run on level ground. also check the fans. if the fan is bad or the bearings are shot, it'll vibrate and make a loud humming noise. find out where the noise is loudest. if it's under the fridge, it's the compressor. if it's inside the freezer, it's the fan.
Aug 28, 2009 | Refrigerators
Fridge sounded like a car revving
Check the compressor fixation are okay.Normally it should be on rubber parts fixed to the bottom.If one of them is not fixed it can vibrate.
Jun 30, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Daewoo FR-147RV Logo
271 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
