Question about Emulex NetJet (NJ01B-NTplus) Print Server
Emulex NetJet Print Server Problem
Trying to set up laserjet 4 with Netjet Print server on a Microsoft XP network. I have two laser jet prints one with HP Print server that works OK and one with Emulex Print Server which I can ping on the network but can't print to. Are they different printer drivers than the HP Printer drivers?
Thanks
Garry
The standard port settings used when setting up a Printer Port is Port 9100 (TCP) when normally communicating with the Jet direct / LaserJet 4 plus printer.
However when using the Emulex Card it s default is Port 2501 (UDP). So within XP change the Port setting to 2501 and it then will communicate correctly.
Posted on Aug 18, 2008
How do I set up an HP JetDirect 170X Print Server with Windows 8.1 Operating System?
Connect the printer to the print server. Push the test button on the test button on the print server. Two pages will print. One of the pages will contain the IP address for the print server. Connect the print server to the router. Now you need to go to the Control Panel and select "Devices and Printers". Select "Add a Printer". When it searches for a printer, select "The printer I want isn't listed". Next, select "Add a printer using TCP/IP address or hostname" and click "Next". Now, enter the IP address from the test print and click next. That will do it.
May 28, 2014 | HP Jetdirect 170x Print Server
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
I want to connect my HP P2015 Laser Jet printer to my Dell Studio XPS deskto computer for wireless printing. What to I need? Thank you.
Your printer has an cable/wired ethernet connection. To use it wirelessly, you need to purchase a wirless print server from HP.
HP Jetdirect Fast Ethernet
embedded print server
(RJ-45 port) for flexible
networking (standard on
the P2015dn and
P2015x models only)
http://www.hp.com/sbso/productivity/howto/it_networkprintserver/basic.html
Jun 12, 2011 | HP LaserJet P2015dn Printer
HP Laser Jet 4700 network card
HP LaserJet 4700 printer comes with inbuilt network card so you don't need to install another network card. If you want to but network card for your PC then go for 100/1000 Mbps network card.
Regards
Ashly
Feb 03, 2010 | HP LaserJet 4700 Printer
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Jul 12, 2008 | HP LaserJet 1320 Printer
LaserJet 1600 offline status
Is the print server being assigned a IP address in your network?
Mar 05, 2008 | Trendware TRENDnet TE100-P1U Print Server
How to install pocket printer server
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Aug 07, 2007 | Emulex NetQue Pro2 (NP02) Print Server
Contact
The following link will tell you how to connect a serial cable & set the address: http://205.200.75.226/support/printer/emulex.html
Aug 02, 2007 | Emulex NETQue Print Server
Changing the IP address
check with the manual of the server that it is having web based management. If yes make your computer ip and subnet mask as per the ip and subnet mask of print server. open the internet explorer type the url as specified in manual enter the username & password as per manual. there will be the setting page displayed where you van change th eip of the print server. if not please write me which type of management it uses to access the settings.
May 10, 2007 | Emulex NetQue Pro2 (NP02) Print Server
Emulex NetQue Pro2 Print Server how do I connect to it
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
Emulex NetJet (NJ01B-NTplus) Print Server Logo
571 people viewed this question
Top Emulex Computers & Internet Experts
David Payne
David Payne
Are you an Emulex Computer and Internet Expert? Answer questions, earn points and help others
