Question about Refrigerators
Cricket noise from samsung side by side refrigerator
My side by side refrigerator makes a noise that sounds like crickets only about 40 percent of the time. It may be defrost stage or something. Is there anything I could try before calling a repair person. The fridge is only 3 years old. The product has suddenly slowly stop freezing for the last three days. There is no evidence of a normal defrost cycle in operation, I guess.
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
  • 958 Answers
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Posted on Feb 12, 2008
SOURCE: Samsung side by side refrigerator not working
The tip with the two power freeze buttons is tremendous! It saves you a lot of troubles and money. I live in Brazil and have such a refridgerator. Of course power here is something that you may have or not. Every time when the power goes out the machine stops working. EVERY TIME you call the service; the guys may show up 2 weeks later and try to sell you a new motherboard. But the nice part is that they don't have with them. They always make a provisional fix: the 2 button one. I never succeeded in seeing what they did and they never told me. Now I know it. Thank you!
Posted on Feb 16, 2008
  • 5 Answers
SOURCE: Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Posted on Aug 13, 2008
tech master
  • 120 Answers
SOURCE: Rattling compressor on Kenmoore bottom freezer refrigerator
IF IS NOT 5 YEARS OLD YET CALL A TECH ASAP THIS MODELS HAVE A COMPRESSOR THAT ARE FAMOUS FOR LOCKING UP AND THE ONLY FIX IS TO REPLACE IT BUT FIRST DISCONNECT AND REMOVE BACK COVER AND RIGHT BY THE COMPRESSOR THERE IS A SMALL BOX ATTACHED TO IT CALL A OVERLOAD REMOVE IT AND SHAKE IT IS IF RATTLES THEN JUST REPLACE THAT PART IF IT DOESNT RATTLE CALL A TECH
Posted on Nov 10, 2008
Do I have a 20 pound cricket behind the refrigerator??
That's the compressor. Check the compressor mounts to see if they are cracked, loose, or have hardened or broken rubber bushings. Also check to see if the compressor housing is improperly touching something that transmits its vibration and acts like a sounding board. Sometimes there is a problem with freezer icing in high humidity conditions, leading to ice buildup on the refrigerant tubing at the compressor (excessive running) - this makes the tubing insulation rigid and things get really noisy. The fix is to shut everything down, let it defrost, and clean out the defroster drain tube.
If you can't find anything like that, you may have something going out in the compressor. If possible, make an audio recording and play it for a service technician at an appliance shop - he may be able to identify exactly what the problem is.
May 08, 2014 | Refrigerators
Turn on predictive text cricket samsung transfix
On the SCH-R470C Samsung phone from CRICKET, you have to brig up the keyboard, (as if you were Texting someone ) and there is a Key on the bottom left side of the Keyboard that looks like a small "Gear". That brings up the "Settings" menu - uncheck the box that says "Predictive Text". Whoever invented that incredibly annoying feature should be severely beaten with both vowels & consonants...
Aug 02, 2012 | Samsung Transfix R730 R 730 Android...
My smeg fridge is making a constant cricket sound noise constantly
first check for a cricket
if no cricket is found, it's likely one of your 2 fans. one will be down by the compressor and the other is inside the freezer compartment.
May 22, 2012 | Refrigerators
Chirping cricket sound
oopppsss.. time for replacement
Jun 19, 2017 | Western Digital 500GB My Passport...
This is the 2nd Samsung Cricket wireless that I have gotten and AGAIN my sounds are gone. It says SILENT MODE ACTIVATED...what's going on with this phone? It's frustrating on emergency calls and it doesnt...
My name is Marty and I work on behalf of Cricket Wireless. We recommend bringing your phone into a cricket corporate store to have it looked at by one of our technicians. They'll be able to help find the exact cause of the problem. Hope this help!
Mar 16, 2011 | Samsung E950 Mobile Phone
After 14 months and 3 refrigerators, I'm giving up. The RF265 and RF263 series refrigerators make loud popping sounds. I've been through two RF265s and one RF263, and they all make the same noise. The...
I have had what sounds like the same problem for over a year with my Samsung RF263 refrig. It makes very loud popping noises like expansion noises when heat hits your house siding or a railroad track. The noises are loud enough that they actually startle people, and our cat. I had a repair man in last May 2013 but no luck.
I finally did a lot of listening, testing, etc. and found the problem. I noticed it would occur whenever the compressor came on. I thought it might be ice build up, so I took the cover plate off over the evaporator in the back of the refrig compartment. There was no ice build up. I then left the cover off and wiring attached and no noise after a day. After a few other trials I added some more weather stripping to increase the distance between the evaporator coils and the cover plate and that help quite a bit but not totally. I still get a pop now and then. Another problem I noticed with this partial solution is that it causes the shelving to not be aligned. A 'V' gap forms between the shelves and they droop a little. I'm still trying to figure out how to fix this but haven't had any good ideas yet.
This is a very annoying problem and a design flaw in my opinion. Whether Samsung has a solution for it I don't know but I plan on checking before my warranty runs out.
Dan
Jan 30, 2010 | Samsung RF265AA Bottom Freezer French Door...
Samsung refrig fan noise-sounds like cricket.
sounds like the bearing is starting to get tight in the fan motor. i would replace the fan motor.
Oct 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ge compressor makes cricket sounds while running
yes from what you've said it is the bearings if there not bad then there on there way. good luck
Mar 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I don't have the cd key for EA Sports Cricket 07 for Windows
u should ask help from a computer expert im 99 percent sure it will work
Mar 21, 2009 | EA Sports Cricket 07 for Windows
Refrigerators Logo
342 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
