I have a plasma tv that has two black lines about 50mm wide running vertically in the centre of the screen
  • 1 more comment
  • jmock85 Aug 17, 2008
    problem is there whether i watch tv or dvd
    problem is the same watching tv or dvds
    thanks at least i know where i stand as far as repairing is concerned
    Scholar:
  • 163 Answers
Check if the socket between Y driving board and Y BUFFER is plugged well. If not, plug it well. If yes then replace Y BUFFER (upper, lower) in respect to the upper , lower part of the dark line on
the screen.
Posted on Aug 17, 2008
    Genius:
  • 1,665 Answers
Service manual Troubleshooting tips:
There appear on the screen one vertical unlit line or a vertical entirely unlit block?
a. If it’s one vertical unlit line, then COF has problem.
b. If it’s a vertical entirely unlit block, then first check if the connection socket between COF and
logic BUFFER has problem. If not, check if the connection socket between the logic BUFFER
and the logic board is normal. If yes, replace the logic BUFFER. Finally, if the problem still
remains when the replacement is over, then replace the logic board.
[7 flexible ribbons attached to the bottom of the screen.These ribbons are called COF's (chip on flexible)]
  • 10,594 Answers
In my opinion, your Plasma TV has problem in video data processing board and / or in panel and needs to be replaced. But as per my knowledge, no company / manufacturer is offering parts / boards any more for Plasma Tvs. Few Brands offer replacement with LCD TV on discount price. Please contact your TV Brand Helpline for further info.
  • Shahid Electronics
    Shahid Electronics Aug 17, 2008
    Thanks for using Fixya.com and vote to my solution.
    Genius:
  • 1,447 Answers
Hi-
does it happen/show when you are watching videos as well from a dvd player? try unplugging and replugging the cables from the back and try changing video output using the menu
keep us posted
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Aug 17, 2008
    Hi-
    Thanks for the info, if your TV is within the warranty period still call your manufacturer for free service, if its not suggesting you send it over to a tv repairman so that they can check on the mainboard of your television.
    thanks for using fixya!
    Guru:
  • 1,894 Answers
Three kinds of detects count for this problem. It could be the Logic board, or the Logic Buffer board, or the PDP panel. Just drop your tv to the warranty depot shop to repair.
  • dewan nafees ahmed Aug 17, 2008
    There are flat ribbon cables that leave the panel and plug into the
    driver boards mounted along the bottom of the unit. If reseating the
    cables doesn't fix the problem you've probably got a bad panel.
    please dont forget to accept the solution if you are OK with it.
    thank you
Fix samsung plasma vertical black bar
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
How to i fix my Samsung Plasma TV which has a 3" wide black vertical bar down the middle?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 29, 2015 | Samsung Televison & Video
Approximately. 2" wide vertical black line top to
You may need to adjust the resolution of your laptop to fill the full screen of the TV.
Sep 27, 2013 | Televison & Video
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Jun 14, 2007 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
