Question about Epson Stylus 880 InkJet Color Printer
Epson status monitor 3(M)
It is printing fine now and no longer says paper not loaded correctly, but when I hit the button on the monitor to see if it is ready ... it says invalid parameter, how can I fix this or what is he problem.
    Genius:
  • 1,447 Answers
Hi-
Trash and reinstall the driver, you are having a corrupt driver.
keep me posted
Posted on Aug 17, 2008
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
Everytime I hit print I get a box saying Epson Status Monitor 3 Could not find specified file.
Go to the start menu and look at your programs under Epson and uninstall the status monitor 3 you don't need it to print. If it's not there try to find it in the uninstall programs under the control panel. If you get rid of it your printer should still print fine you just won't get all the messages from it. You can still do everything you need from the front panel. Just download the user manual from Epson.com You can still download the status monitor 3 from Epson if you really need it, but it may not work because of the previous installation.
Aug 25, 2009 | Epson Stylus 880 InkJet Color Printer
Status Monitor isn't hihglighted so I can't check
This can only be done by getting a new status monitor software . Follow my instructions:- STEP 1 - Install the Epson StatusMonitor software. This program comes on the CD included with the printer. It can also be downloaded from the Epson Web site ( http://download.cnet.com/Epson-Status-Monitor-2/3000-2116_4-10024738.html ).
STEP 2 - Open the Epson StatusMonitor program in any application (such as wordprocessingmag-glass_10x10.gif, spreadsheets or Web browsers) that allows you to print. Click on the "File" menu tab in the control bar of the application.
STEP 3 - Select print or page setup from the "File" menu. A dialog box will open. In that box, click on the "StatusMonitor" icon, which will open the "Epson StatusMonitor" dialog box. Also, you can click on the "Utility" icon and then the "Epson StatusMonitor" button from the "Utility" dialog box.
STEP 4 - Click on the "Update" button to update the display (if you do not think these levels are accurate) when the "Epson StatusMonitor" dialog box displays the relative ink levels for each cartridge in the printer.
STEP 5 - Go back to the "Print" dialog box to change the way that the StatusMonitor utility monitors your printer and ink levels. Click on the "Utility" button again.
STEP 6 - Click on the "Configuration" button in the "Utility" dialog box. The open "Configuration" dialog box will let you adjust settings such as ink level warnings and ink level monitoring before each printing.
Aug 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Print error occurred. Please see documentation.
Check status monitor at your OS. Find RX620 adjusment program at indoreset.blogspot.com. Check status from the adjusment program. It is more detail. General error at display or OS status monitor can mean many posibilities error.
Jun 30, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Jun 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Pause & ready led blink alternatly after initilize
Check if the paper type is set correctly (in thebackside right there is a lever to set continuos paper, or single sheets).
May 03, 2008 | Epson FX 1170 Matrix Printer
Epson CX5800F printer Netgear PS121 Print Server difficulties
Here is a workaround:
http://newsgroups.derkeiler.com/Archive/Comp/comp.periphs.printers/2007-08/msg00456.html
Another thing to try if it STILL doesn't work is
Printer&Faxes>>Properties>>Advanced>>"Print Directly to Printer"
Just remember to restart after you try both of these. The Status Monitor in it's current for (at least for me) simply sucks.
Dec 04, 2007 | Epson Stylus CX5800F All-In-One InkJet...
Epson Stylus 880 InkJet Color Printer Logo
475 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
