Question about Samsung YP-K3 MP3 Player
Samsung YP-K3 MP3 player will not turn on?
Battery is charged, even if it wasnt it would tell you it is low, no lights when I try to turn on. Also a posted soution had suggested to reset the mp3, how do you get the back cover off??
  • Anonymous Nov 16, 2008
    my samsung yp-k3 wont turn on. it had full charge when i last saw it. how do u get it to turn on?
Hi.. just had the same problem a few minutes ago and found a solution posted by preciouss_me from the other link..so i tried it and it work. I did reset the button at the back and whoala! it turned on and no files have been deleted..i hope it works for you too. thanks!
Posted on Oct 28, 2009
  • 4 Answers
Simelar problem to all above plus PC would not recognise the unit when connected. Solved however by going into Device Manager on PC, uninstalling it and then plugging back into PC. As it is all plug and play it took it as a new device and everything working perfectly again.
Posted on Aug 19, 2008
My sumsung YPK-3 mp3 player does not charge. When I connect to the PC the usual charging screen comes up saying it is connected and is charging. Even after over 5 hours, it did not charge at all and when...
The battery is at fault. The charging circuit is fine as it says CHARGING. As the battery is at fault you may like to as Samsung to replace it if the device is still under warranty. Else replace the battery.
Jul 05, 2011 | Samsung YP-K3 MP3 Player
Yp k3 player wont charge....
O NOW LISTEN 2 ME CAREFULLY I HAD THE SAME PROBLEM the nokia charger which is there u can use that by getting a connector the connecter is a small type of wire and it is really helpful u can try in any electronic store near ur house i can try sending it 2 u if ur in india it comes hear for Rs20 now it even charges faster
Apr 22, 2008 | Samsung YP-K3 MP3 Player
Say it is charging but it's not
You may acually have a bad battery. I'de suggest a new battery first, if it says it's charging. The other problem could be a open connection from the battery to the power supply on the board but I'de take a close look at the battery first. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Samsung YP-K3 MP3 Player
Frozen
It didn't work for me, so I just waited till the battery drained out and charged it and voila.
Jan 04, 2008 | Samsung YP-K3 MP3 Player
WONT TURN ON!!!!
Why don't you just take it to Best Buy2.gif or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Dec 25, 2007 | Samsung YP-K3 MP3 Player
Brand new Samsung YP-K3 charging FOREVER..
well have had my k3 die on me once, pressed reset on the back and it worked again (this in the it doing nothing anymore case) as for the cgarging thing try it on another computer, when I charge my k3 at work it charges all day but I don';t get a full battery, at home I charge it for bout 2 to 4 hours to get full battery. I think it has something to do with ho many things u have connected to ur usb ports or how much output ur computer gives to ur usb, maybe it goes to like a lower voltage to preserve electricity, no idea how to change this but unplug unneccecary things.
Dec 09, 2007 | Samsung YP-K3 MP3 Player
Samsung yp-k3
Have either of you both tried downloading the drivers for the device?
I used the included CD which had also some software which I don't use... Drag&drop works for me!!
Anyway->
Try Samsung's site ---
http://www.samsung.com/uk/support/productsupport/download/index.aspx
Hope it helps...
Andy
Nov 28, 2007 | Samsung YP-K3 MP3 Player
Samsung YP K3 only lasts for 2 hours
1. totally discharge the battery so it wont come on.
2. Charge the battery fully
3. Reset the player
Now check how long the battery lasts. If it is still 2 hours there is a problem with the battey and you will need to return the player.
Oct 29, 2007 | Samsung YP-K3 MP3 Player
Samsung YP-K3 MP3 Player Logo
609 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
