Maytag SAV571EEWW Washer Logo
Posted on May 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change brake pads on maytag washer - Maytag SAV571EEWW Washer
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on May 31, 2011
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2734553
Points
22413
The following link explains step-by-step how to replace the braker rotor and stator on the Maytag model you listed this question under:
http://www.fixya.com/support/r3574320-maytag_washer_squeaking_problem
Please read through the steps and let me know if you have any questions. There is a helpful ink included where you can search to find any special tool requirments.
Refer to the following websites for helpful exploded view parts illustrations:
searspartdirect.com
pcappliancerepair.com
appliancepartspros.com
Use the exploded view drawings to assist you with locating and properly identifying any parts you may need, and to assist you with removal and reassembly.
3helpful
2answers
Maytag Performa PAVT920AWW washer makes a squealing sound
i am sorry but i had this problem happen before with my customer maytag performa, what i found out is that the brakes become crystallized, causeing a squeaking noise, remember in agitation, the brakes stops the the drum from spinning, what i advise you to do is change out the breaks or take the brake pads and rub them with sand paper
thanks
How to replace the brake pads on a Myatg Washer sav515deww
Searspartsdirect.com just input your model number. Look at the figures to find the part needed and order.
Screeching noise in maytag topload washer
The following link explains the problem you are having with your Maytag:
http://www.fixya.com/support/r387833-maytag_washer_squeaking_problem
It is common for the brakes on Maytag top loaders to wear and make noise, as well, as the snubber. There is a helpful tip that you can try to quieten the noise if it is the snubber. DO NOT oil it, or lubricate with any petroleum based products! This will ruin the unit and actually make the problem worse. NOTE: If the snubber is excessively worn, it was also cause vibration on the spin cycle.
If the brakes are worn, however, you can put a light film of oil on the brake pad. It is common for the pad to collect moisture in humid and damp climates and start to squeak against the brake stator. The brake pad consists of a rotor with a leather edge (pad). The leather can absorb moisture and begin to squeak against the brake stator. Oiling it slightly will get rid of the noise.
Confused? If you have questions, please let me know. I hope you find this information useful.
NOTE: There is a follow-up comment at the bottom of the link I provided from another user. The method this person used to release the tension on the brake can save you from having to purchase the brake release tool.
3helpful
2answers
Brake Squeal on Maytag MAV5000 AWW
Here's the same advice I gave another person with a similar problem to yours. The squealing can be caused by the brakes, or a worn snubber. It's usually a combination of BOTH. Since you may have to take the to disassemble the unit to repair, it only makes sense to replace the snubber as well. The part costs less than $10 in most cases.
It is common for the brakes on Maytag top loaders to wear and make noise, as well, as the snubber. There is a helpful tip that you can try to quieten the noise if it is the snubber by using corn starch. DO NOT oil it, or lubricate with any petroleum based products! This will ruin the unit and actually make the problem worse. NOTE: If the snubber is excessively worn, it was also cause vibration on the spin cycle.
NOTE: You cannot access the brake pad or snubber by simply removing the front of the washer. You can SEE them, but you won't have full access until you disassemble the washer as outlined in the link I provided.
Maytag won't agitate during wash
sounds like you have a broken sety fo brake pads, just replaced a set today for same reason, open the lower acess panel and with a flashlight look into the bottom , your lookin for brake pads( theyre probably broken and laying under unit.)
1helpful
We bought a Maytag Washer Dec. 07. The machine started to squeak shortly after the purchase. I was hoping it will go away, but it is not. Each time I use the washer we can hear the squeak through the whole...
The brake pad is squeaking in the brake drum. Like when the brakes on your car get glazed. It's annoying, but it won't affect the operation. Call the store where you purchased it and set up service to have it repaired. If the tech they send doesn't have a brake tool, or seems clueless, have them send a different tech. Be sure they replace the parts - not just scuff up the pads and drum already in there - Maytag's buying!
Unfortunately, there's no guarantee this will permanently take care of the situation. I have noticed that doing larger loads actually helps condition the brake seating surfaces when the parts are new.
Maytag Washer, SAV571EEWW
yes if the pads are damaged it will spin in agitation. Pads are easily replaced.
Maytag washer sav365zaww
LARRY...I HAVE THE SAME MODEL AND THE SAME PROBLEM JUST STARTED FOR THE 3RD TIME. CALLED THE REPAIRMAN THE FIRST TIME, MYSELF THE 2ND. MINE IS A BROKEN(IN TWO) BRAKE PAD. THERE ARE THREE OF THEM. REMOVE 2 SCREWS AT VERY BOTTOM OF WASHER FRONT AND REMOVE PANEL. YOU CAN GET TO THE 2 FRONT PADS FROM THERE ALTHOUGH TIGHT FIT. I ALSO READ THEY SHOULD HAVE CLEAR LITHIUM GREASE ON THEM, ALTHOUGH THIS DOESN'T MAKE SENSE TO ME. GONNA GO DO MINE AGAIN...GOOD LUCK....KHRIS
Maytag performa
Sounds like your motor brushes are very worn.(Its a bit like grinding metal when a cars brake pads are worn.)Should only cost 10 or so pounds for new ones,access to the motor will be required.Unplug washer b4 changing.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
