Question about Intel Pentium III, 800MHz (229725001)
EZeroDivide problem When I try to open WinAvi program, the program takes a long time to try to open and ends up coming up with a little window with 'EZeroDivide' written in it and a OK button. When I click on the OK button the program shuts down.
  • Anonymous Sep 18, 2008
    i've got the same problem and uninstalling and reintalling the proggie didnt make a diff., im still getting that error
  • 781 Answers
You need to Uninstall and then reinstall program
Posted on Aug 17, 2008
Youtube is not working i cant watch movies and cant downland any movies
is there any error message pop up when playing youtube videos?
you can install a plug-in software to download and convert youtube videos you like. Like WinAVI YouTube Download or WinAVI FLV Converter.....
Some introduction on: http://www.winavi.com/flv-converter/index.htm
u can first check and then download for try.
Nov 28, 2012 | YouTube Videos
What size dvd 's are used to burn a movie from my Acer aspire 5517? I tried to burn a dvd and cd once and was unable.
The process is rather simple once you get the hang of it. Many people use various conversion software programs to convert their movie file to prepare them for a DVD. Although in the beginning it is complicated but after a couple of stabs at it. You will be burning movies.
The size normally would be 4.7 Gig standard DVD-R you can use RW if you plan to rewrite over the movie later. It will hold a single movie or approx: 4-5 depending on size if the files are not converted. You can convert the movie files using Winavi this is what I use. or you can try to find any free burning software program out there. Winavi for me was the simplest to process it is a approx: 3 step process.
You will be burning the Video from the file once converted. The audio is included during the burning process. All you need is one DVD-R place in the burner. Then open the conversion software and open the video file and convert and burn that is about it. For higher graphics quality it will take more of the disk space for less or normal it will take approx half the disk that way you can fit two movies on one disk basically. So the process is converting the movie to be prepared for the DVD to work on standard players.
Check out Winavi this is what I would suggest maybe someone else knows a free software conversion program you can use. John
May 10, 2012 | Acer Computers & Internet
When you open the door, the window drops a little and doesn't come back up until door closes normally, but my problem is when i open the door the window drops a little like its supposed to but instead of...
You may need to store the end position of the windows in the control unit. I would try the following, with the door closed, and the window partway open: Close the windows with the rocker switch ONCE. Then press the front half of the rocker switch again, this will store the end position in the control unit. Good luck!
Oct 18, 2010 | 2001 Porsche Boxster
How do i convert my video to fit my computer...i have a windows xp.
use WinAVI converter and try different combination in the convertion option.
it will take a long time and many tries to get the correct resolution.
Dec 06, 2009 | Microsoft Windows XP Home Edition
Boot problem
Better open up ur case [while it is switched off],check the cables of ur HardDisk take them out and put them back again.Then also check ur RAM try pressing it a little into the slot.Solves my problem most of the time.
Jun 01, 2009 | Microsoft Windows XP Home Edition
I tried to install my hp laserjet 3015 several times but I failed
  • It may take a little time for the CD to begin reading. Hit retry.
  • The CD may be damaged
  • The program may not load automatically
  • Go to the Start menu and then click on "Run". When the Run window appears, click on browse. Choose the D drive (or the one that reads your CD). Look for a file that ends in setup, execute, or install (these words my be abbreviated)
  • Double click on the file and it should be displayed next to "open" in the "Run" window.
  • Click okay and the program should begin to install.
Jan 28, 2009 | HP LaserJet 3015 All-In-One Printer
Iriver D5 korean
iriver has problems with its video playback...
only certain formats can be played...
the iriver should have come with a converter on the provided program so just use that to convert the files to the format you need.
if that doesnt work try and get winavi converter.
Aug 29, 2008 | iRiver X20 MP3 Player
How do you transfer
You need a capture card already in your computer (or a simply IEEE 1394 or a USB 2.0 port) depending on the quality of video you want. Then you need a capture program. For a low price, b ut still decent quality program you can use Adobe's Premiere. I like Premiere because it's VERY user friendly and a quick learning curve. Once you have the video captured (be sure you have enough disk space on your HDD (I have 4TB in external drives for video editing)) edit it how you want the final product to look, export the video to an AVI, open your Authoring program (I suggest 2 different angles: 1 (for EASY) either WinAVI or Nero VIsion, super simple program but the quality is lacking, or 2 (for the creative) Adobe Encore, high quality but it takes a little time to learn the software. Create a DVD Folder from Encore or any authoring software, burn thr folder using your Burn Software (i like Nero 7). Boom, you have a DVD.
May 07, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Nero 8
Hey there WWID, I use nero vision to convert VTS from PAL to NTSC. When converting AVI or other formats, I use ConvertXtoDvd, or Winavi as a second choice. These programs can also burn to DVD when finished conversion. ConvertXtoDvd seems to also override some protective features found in some video files, which I believe was the case with the problem you mentioned earlier. Good Luck!
Feb 09, 2008 | Adobe Photoshop 7.0 for PC
Intel Pentium III, 800MHz (229725001) Logo
500 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
