Electronics - Others Logo
Posted on May 31, 2011
No record i dont know what happen!! maybe is the head its dirty.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
376
Points
6
What is the actual problem?
Akai four track reel to reel won't record though vu meters say it is.
The vu meters only show that there is an input signal. The meters do not mean the deck is actually recording. If the deck will play a previously-recorded tape, how well does it sound? if the sound quality is muffled or very low, the play-back heads are dirty. If the playback heads are dirty, then the erase and record heads are too. In the tape path, the direction your tape moves from supply reel to takeup reel determines which heads are in which order. Most R-to-R decks play from left reel to right reel. The magnetic heads are in this order, with the the arrow indicating tape transport direction:
Supply Reel moves tape across > Erase head first, then across > Record head second, then across > Playback head. Some machines use the same head for record and playback, but no machine uses the erase head for anything but erasing pre-recorded material on the tape.
First, using tape recorder head cleaner or rubbing alcohol, clean the erase head (the first one the tape moves across) thoroughly with a Q-tip. If the heads are VERY dirty, use a pencil eraser AND the Q-tip. If this head is not clean, it will either not completely or not at all erase the material already on the tape. If the tape isn't erased, you either will get your new recording laid over the top of the existing one and it will sound like gibberish, or the new recording will not be recorded at all, and the original recording is all you will hear. Next, clean the second head the tape passes over. Usually this is the record head. If it is dirty, it will not record clearly or at all the material you are trying to record. Last, if there is a third head (most decks have this), clean it thoroughly as well. This is the playback head, and if it is dirty enough, you will hear nothing, although your new recording may very well have been laid down on the tape. Always clean all tape heads at the same time; in other words, don't just clean one head and not the rest of them. Clean all tape deck heads AS WELL AS the capstan (skinny metal pin that rotates) and pinch roller (the rubber wheel that 'pinches' the tape between itself and the rotating metal pin) thoroughly, rethread your tape through the head array, capstan, and pinch roller onto the takeup reel, and see what happens. If everything is clean and you still don't get any playback of your recording but you do get playback of pre-recorded tapes, then the problem is in the record circuit, and can be anything from faulty input stages to a bad head--deck heads DO go bad, although not often. If this is what happens, you have to take the unit in for repair by a qualified technician.
1helpful
Jvc gr-ax35 only plays black and white on 3 different sources i.e. tv, dvd recorder player and usb capture. could this be tape detrition or dirty video head
i would take it and get it serviced
i think the tape isnt running at quite the right speed perhaps a dirty bearing
usually if you get black and white from a colour video
then its either recorded in black and white or playing back black and white
so if you record then test it using a a vcr and a converter vhs tape box then you can see if its recording in black and white
then youll know its something too do with either the colour carrier etc component of the video its outputing
dont think its a dirty head
but you can clean it easy enough
i use a plain manila envilope and use the inside of its paper
the outside is smooth the inside is rough
its just right to clean the head drum
and some small lint free cloth to carefully clean the mecha
i use IPA isopropile alchohol {get from the chemist}
2answers
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
The playback is staticky (spelling???)or maybe the right term is noise - what can i do about this?
Kinda mosaic-like noise?
Possible cause
-dirty playback head
-dirty or worn-out tape
-running tape recorded from different camcorder.Tape will play back best in the same cam that recorded it.
Colored, pixilated bars appear during playback
It is very common when the magnetic heads got dirty. Buy a Mini DV cleaning tape, follow the instruction clean the heads by playing the cleaning tape for a while. Record NEW video and playback to test.
Please know if you play the old video recorded buy the dirty heads, you may not get clear picture, because here is not correct data recorded on the tape.
Hi, i have a sony z1...
I assume that you can see live view to record on mini dv cassette but can't see recorded image in playback.
Let me know when you playback mini dv cassette, does time counter run time intervals or stays blank on LCD / eye finder?
If this happens, you have dirty / clogged video heads in camera and need to use good quality mini dv head cleaning cassette to clean heads. This will resolve problem.
Need further help, let me know please.
Thank you.
JVC GR-D350U problems
I have seen this many times, and it is usually always dirty heads, and it is a bigger problem when you record in long play. If the heads were dirty when the tape was recorded, then that is how the image was stored and will stay that way. So make sure you clean the heads before an important recording. Try cleaning them again with a new cleaning tape, and it just might come good if it was originally recorded fine.
D8-->Hi8 switch.
Hello DutchyFL,
Sony recomends to use Video Head Cleaning Cassette in Playback mode. Video Head is still dirty in your camera thats why you can't see D8 picture.
Top Sony Electronics - Others Experts
Sean Wright
Sean Wright
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
