Can not getdvd 16xto copy tried changing the speed with no luck
    President:
  • 2,961 Answers
The dvd media may not be compatable with your drive, try another make
Posted on Aug 17, 2008
How to chance shutter speed in canon sx 260
For direct control over the shutter speed, set your camera to the Tv (time value) mode. See the "Specific Shutter Speeds (Tv Mode)" section in the user guide (page 140 in my copy).
If you need the user guide, you may download a copy from here.
Dec 06, 2012 | Canon Powershot Sx260 Hs black 12.1mp 20x...
The tines on a honda f220 always spin and don't change speed when clutch is engaged but speed up when throttle is increased. Adjusted cable with no luck.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
Sep 24, 2012 | Honda 25cc 4-cycle Mini Tiller
I have a stand alone dvd/cd duplicator at our church having trouble with. Cant copy onto dvd-r's. Master can be dvd-r or dvd-rw and will copy onto dvd-rw. when i try to copy onto dvd-r's, it will run for...
The two common problems, copier doesn't like color of discs etc, and slowing the speed that leave you've already tried. After those the most likely thing is that one of them has heads that are out of alignment. You could try copying cd's as they have coarser and the heads don't have to be as accurate. If that works then it is very likely it's the heads out of alignment. If they won't record on the cds at all it still can be the heads out of alignment too, but this test may help determine which drive is out of alignment.
Mar 06, 2011 | Computers & Internet
How do i change my aperture setting on my samsung v800?
Turn the mode dial to "A". Turn the jog dial to change the aperture and the camera will change the shutter speed to match. You can also go to the manual mode, where you have to set both the aperture and shutter speed.
Full details are in the "How to use the APERTURE PRIORITY mode" section of the manual (page 22 in my copy). If you need a copy of the manual, you may download one here.
Aug 24, 2010 | Samsung Digimax V800 Digital Camera
Change the paper setting to card in tray 3 on a Infotec copier ISC 2020
go into the user toools and select paper then scroll down to paper tray 3 and change the size here to the size youj need then scroll down again to the section for paper type and select card thick this should slow the copy speed down as well to feed hte card better.. you could also put in bypass hand feed for better feed. Good Luck A
Jul 25, 2009 | Office Equipment & Supplies
Cannot copy DVD because no write speed is selectable
Try to uninstall and reinstall the roxio software in the system and it will fix the issue.
Hope this Help
Cheers!!!
Jul 16, 2009 | Roxio Easy DVD Copy 4 Premier
Which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
