The picture on the screen as all fuzzy and cant get a clear picture without having a shadow or it being fuzzy
    Novelist:
    Scholar:
  • 141 Answers
Do you have a led or crt display? It could be just your display settings. Go to control panel /display properties /setting tab / and try changing the screen resolution. If no difference try the color quality. You can change the color bits without hurting any thing. Just remember what you changed it from and to.
If this doesn't help maybe you'll need a new screen.
Posted on Aug 17, 2008
SOURCE:
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
After having our tv in storage for aver a year, now it has a green shadow to it. What could be wrong/
Not sure I understand what you mean by green shadow. I would check the fluid in the green and blue CRTS and verify they are clear. I would do this if the green color seemed fuzzy or blotchy looking on the screen.
When looking on a blank screen, do you see any arc lines of either green, blue or red? If so, you would need to lower the screen voltage for that particular CRT.
Feb 14, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have red and green shadow on top and bottom of the screen.
Ur Convergence board is dead or deffective with the IC chip.
Aug 17, 2009 | Akai PTH5498 54" Rear Projection...
Clear picture, then rainbow colors, then fuzzy, then clear again.
logitech cams only work in UVC mode not drivers
unless you have 10.3.x software on the mac. then you can run 8.0.1 on the mac. otherwise you need to upgrade the cam.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/popup_adp.php?p_sid=ebAIcqDj&p_lva=228&p_li=&p_faqid=6471&p_created=1176155953&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MywzJnBfcHJvZHM9MCZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9MzQyOA**
here is a list of mac complaint cameras.
Jul 09, 2009 | Logitech Quickcam Chat Webcam
REDDISH Screen with Samsung Monitor
You should changes the connections first!!!
Monitor connected directly to TV/ CPU without passing the projector unit.
I think that's the problems!!!
Dec 19, 2008 | LG Flatron F700B 17" CRT Monitor
The picture on my tv is warped
Hello jbvail86,
This problem you are having is a convergence problem. The convergence amplifiers are malfunctioning. Both Amplifiers need to be replaced. You will need a schematic, and a multimeter to check the voltages on the pins of the convergence amp ICs. Once you find that the ICs are bad you will need to de-solder them and the biasing resistors and replace the ICs and resistors. The schematic will help you find the proper resistor values.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fuzzy and flickering picture
try bending the connectores slightly up and down and check if the problem will be fixed, if that seems to solve the problem purchase anothe AV cord for your PS2 also try testing your PS2 on another tv and then let's see if it will solve the problem
Jul 05, 2008 | Sony PlayStation 2 (PS2) Console
Open Questions:
-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A
Oct 16, 2019 | Computers & Internet
-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}-\&;-Avast Customer Care Phone Number #{888*.499.*5520}
Computers & Internet Logo
126 people viewed this question
Ekse
Alun Cox
