It's important to understand how you can have data connection to your phone so as to access internet e.t.c.
Basics:1.
Access through the Network:
Mobile Providers (Vodafone, e.t.c.) provide data access to the users on request (or by default in some cases). This data access is through the NETWORK of the mobile operator and uses 2G, 3G, GPRS, EDGE protocols to access the network.
2. Access through WiFi or WAN:A smartphone can access internet using the WiFi or WAN protocol (wireless lan). In order to connect to the WiFi network you need capability from your phone and also to find an Access Point of Wifi (AP) to connect to. WiFi networks are FREE or PAID. You can find free networks usually in central squares, caffee's e.t.c. Also, some providers (Vodafone, e.t.c.) provide WiFi APs and you can use prepaid cards or fixed contracts in order to access them.
SGH G600Unfortunately your phone DOES NOT support the WiFi protocol, so you can only access internet through the 1st option.
In order to do that, we need that your operator allows the DATA traffic for you and we also need to setup your phone in order to accept/send DATA.
How to do it.1. Mobile operator settings: Pls call your mobile operator and ask them if your number has DATA allowed (DATA plan, or DATA connectivity). If so, you are OK. If not, pls check the price rates (per MB or per usage time) and -if it's within your budget- ask them to activate DATA to your phone.
2. Phone settings: Your phone has the following symbols that indicate Data connection:
GPRS signal
EDGE signal
In order to setup the Data connection there are the following configuration options in your phone:
1. Menu -> Setup Wizard. Setup wizard can setup your phone for various tasks. Try it.
2. Menu -> Browser Settings. You can select the connection profile to be used for DATA.
take into account that in order to setup a DATA connection you need to setup the AP of the GPRS/EDGE as well (usually something like internet.vodafone.com)
BUT the easiest solution your you is to call your provider, give your number and phone model/type and ask them to send you an automated message that has all the needed settings for your phone so as to have access to DATA.
You click on the message send and all needed settings are OK.
You can now access internet!
If above solution was helpful, pls rate it.
Thnx.
