Question about Whirlpool GSC9455 Top Load Washer
White particles left on clothes after wash cycle has finished
Cant find machine manual washing machine is whirlpool top loader around 9 kg size about 5 years old or more made in USA problem is leaving white stuff on clothes after washing dont know if there is place to empty build up as cant find manual for machine could you help thank you.
  • Anonymous Mar 24, 2009
    i have the same problem , whilpool super size top loader,
    dont know if ther is a lint trap but white stuff on clothes , is driving me crazy!!!
vest6
  • 196 Answers
SOURCE: Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Posted on Jan 12, 2008
  • 1028 Answers
SOURCE: Hi I have a Whirlpool 8255e
sounds like timer hanging or bad timer motor ..in either case only solution replace timer
Posted on Aug 11, 2008
  • 1028 Answers
SOURCE: washing machine
bottom right corner behind the little door
Posted on Sep 27, 2008
stephanos18
  • 144 Answers
SOURCE: Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Posted on Mar 25, 2009
kel1guy2002
  • 3740 Answers
SOURCE: washer leaves trash on clothes when finished. has
It sounds as if there is a soap buildup in possibly a couple of places and it is coming loose then ending up on your clothing. If you changed brands of soap this can happen also. The soap buildup can be under and inside the agitator. It can manifest itself in large calcium type flakes in the washer when it finally breaks down and you see it. You can remove the agitator by opeing the top of your agitator and removing the retaining biolt then lifting out the agitator. Use a putty knife and scrape off the inside of the wash tub under the agitator. Also take the agitator either outside or to the bathtub depending on weather and scrub it clean on the bottom and on the inside of the agitator. If after all of this you still have that same material show up you may have to remove the wash tub itself and clean the outer tub with a putty knife. There is a special tool that locks into the 4 slots of the tub nut used to remove the tub nut. You can buy it at most appliance part centers. Tell them you need a tub nut removal tool for a kenmore / whirlpool top loading machine and they will walk back and get you one straight away. Good luck andI I hope this resolves your problem.
Posted on Jan 11, 2010
Clothes have lint on them when the washing cycle is finished is there a lint area i need to clean
The newer Whirlpool top-loaders have lint screens on the inner tub and not accessible. These are supposed to self-clean during the drain cycle. I've heard that liquid fabric softener and detergent build-up may clog the screens when lint sticks to the gooey screens. Try something that will cut the goo like vinegar or ammonia in a small load level without clothes. Without clothes in the washer, that is.
Older Whirlpool washers have lint filters located above the tub, on the lid opening.
Good luck from Detroit, MI.
Jul 18, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
I bought the Whirlpool Duet to replace my old standard washer & dryer and I find that the wash time is longer than the old washer. Even the quick wash takes about 1 hour. Am I doing something wrong...
I assume from your comment that your old washer was a top loader. Yes, front loading machines typically have longer cycle times than top loaders. There are several contibuting factors... first of all, the wash action of a front load is to oscillate the drum back and forth as well as provide a slow tumbling motion whereas a top loader w/ agitator or impeller has a more aggressive action. The more aggressive action rolls and tumbles your clothes more often and therefore cleans faster. Also, because front loaders spin very fast (up to twice as fast as top loaders) to reduce the amount of moisture left in the clothes, they need to have balanced loads. They accomplish this by testing and rebalancing your load several times during each cycle before beginning to spin.
That was a long answer to your question- no, you are not doing anything wrong.
Good luck.
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWOE 9559B 1200rpm 6th Sense Washing Machine, 9 kg instruction book lost; can you provide me with a copy please
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Jan 23, 2011 | Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
Washing comes out with marks
Yank that dispenser off the top of the agitator and wash some clothes without it.
Apr 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water usage per cylce
water usage is about right. top loaders use far more and so does hand washing
only way there would be excessive water usage is if machine were overfilling
Aug 13, 2008 | Washing Machines
Jan 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Lint or soap residue
Sounds more like a build-up of particles that may very well be in the water supply. There is something that you can try to get rid of these particles.
1. With the machine empty start it in normal eash mode and let it fill. Add 1/2 cup bleach to the water and let the machine run completely through the wash cycle. This will help remove any unseen stains or build-up.
2. When the machine drains and begins to refill on the next cycle, add 1/2-1 cup of white vinegar and again, let the machine finish its' cycle.
3. Run the machine through the wash cycle one more time to remove any vinegar that may have been left behind.
This is not a guaranteed method but I have had some success.
Dec 03, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool GSC9455 Top Load Washer Logo
213 people viewed this question
Dan Webster
Dan Webster
Sal De
