Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Lost screw to front floor nozzle.
I lost the screw that holds the front floor nozzle to the vacuum. It's all I need to replace. Is there a place that will sell me just this single screw, or can anyone give me the specs on the screw required that I can buy at my local hardware store?
  • 52 Answers
Go to http://www.bissell.com/Product_Search.aspx?Criteria=9500+pro-heat
and click on parts & accessories.
Posted on Aug 25, 2008
How to fix series 3500 upright vac
With vacuum laying flat with back facing up, remove the 5-6 screws from the bottom of the nozzle, turn on it's side, and pry into 2 slots on either end of the bottom of the nozzle to release the top cover. Lay vac flat on the floor/bench face up, remove the 2 small screws on either end holding the roller brush in place. Pop the belt end of the brush roll out of place, place new belt in, and simply reverse all previous instructions. With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Hope that helps! Mick
Sep 24, 2014 | Electrolux Vacuums
I have a 7950 Bissell. I can't get it to **** up from either the tools or floor area. I tried adjusting the knob on side but still no luck. Any suggesions?
First check to see if there is suction at the motor duct. If not contact you local BISSELL Authorized Service Center at http://www.bissell.com/customer-support/.
If there is suction,
a) Check if the small rounded window tabs on the Floor Nozzle are locked in
their mating slots and not inadvertently lifting the tank up out of place?
b) Check to ensure oval seal is in place at the top of floor nozzle window.
c) Check the diverter knob for proper setting and the diverter door opens and
closes properly. If no, and it does not appear to be broken, remove the floor nozzle window, open diverter door manually, keeping the flat
side of the door against the unit. Set the diverter knob on the tools setting.
Manually close diverter door until there is resistance, hold it in place while
turning the diverter knob towards the floor setting to lock it back in place.
Reinstall the floor nozzle window. (If diverter door will not lock back in place,
go to a BISSELL Authorized Service Center).
d) Check for the black foam gasket under the diverter door. Replace if
necessary.
e) Check floor nozzle window to ensure it is screwed down properly. If there is
a ¼" gap between the window, where it wraps around to the side of the
unit, and the base on the slanted section, reinstall window.
This gap can be eliminated by installing the tabs at the top of the window,
hold it in place, then push up from the bottom of the window to bow the
window, push it against the unit and then evenly slide it down into place.
f) Check half moon window to ensure it is screwed down properly on
CleanView models. The floor nozzle window should be lower to the floor
then the half moon window.
g) Make sure tank is not full on the outside of the bladder.
h) Check the tank lint screen for debris. Remove it to check.
i) Check tank lid and tank for damage.
j) Check float and baffle to ensure they are properly installed properly. The
baffle should be even with the top of the tank
May 29, 2011 | Bissell 7920 ProHeat Pro-Tech Upright...
How to get the vacuum apart to change the belt
Turn power nozzle bottom up.
Remove the 5 screws.
Insert tip of a standard screwdriver into each square hole on either side of the wheels and twist to release the tabs.
Holding the power nozzle together, turn it over.
Lift the back of the cover up, then remove it.
Remove the screws at the ends of the brush.
Lift out brush.
Remove belt and replace with new belt.
Place brush back into slots and replace screws.
Check belt to make sure it's settled correctly and check tautness. It should have some give, but not much.
Replace cover by inserting front lip into the slot at the front of the base. Carefully manipulate into place, ensuring the latches click into place.
Turn PN bottom up.
Replace screws.
Feb 25, 2011 | Electrolux Epic 3500 Vacuum
OK ,maybe I have a better explianation to my problem. The clear view window is rubbing against the carpet. Yes I understand that the machine has to be used in a foward and back motion. How can I prevent ...
From what you are describing the half moon shaped window behind the main floor nozzle is dragging on the carpet. There are two screws that hold the half moon window in place. Make sure those screws are tight then take off the front floor nozzle and re-install it, making sure the front nozzle is hooked to the half moon window in the center. If you need further assistance call BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Sep 27, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
The cleaner no longer vacuums up the water. I have to use the tool device to get the water up. marleneodlekemp@hotmail.com
Try the following suggestions to see if you can get your machine suctioning properly:
1) Remove the Tank-in-Tank Assembly and place your hand over the motor intake valve. This valve is located next to the Floor Nozzle gasket (at the top of the Floor Nozzle window) and behind the SmartMix Bottle. If you feel vacuum-like suction at this area, your suction power of the unit is working but air is escaping at some point. If there is no suction at the motor intake valve your machine will need to be inspected by an Authorized Service Center Technician.
2) It is possible the Floor Nozzle on your machine is inserted incorrectly. This would directly affect the suction of your machine. Please follow the directions below for removing and replacing the nozzle.
Before starting, please be sure the machine is unplugged and the machine handle is reclined.
To remove the Floor Nozzle window, first detach the Phillips head screws located at the base of the nozzle. Then, remove the Tank-in-Tank Assembly. Next, pull forward at the top of the Floor Nozzle window to release the tabs of this window from the receiving holes of the machine. This window is designed to allow access for cleaning.
When replacing the Floor Nozzle window, please be sure the tabs at the TOP of the nozzle are properly inserted into the receiving holes provided. If you do not have the tabs in place properly, the suction power of the machine could be affected.
Rotate the window down into place and replace the screws.
3) Ensure that the Ready Tools knob (diverter knob) is in the proper setting and the valve opens and closes freely. Ensure the black foam gasket is in place under the valve.
4) Check to ensure the Tank-in-Tank assembly is seated properly and that it is not full of dirty water. (If this tank has a drain cap, make sure it is in place and that it has a black o-ring).
5) Check the float and baffle to ensure they are properly installed on the Tank-in-Tank. The larger square portion of this part should be below the clear baffle of the tank with the red flag portion of the float resting on top of the baffle.
6) Check the Tank-in-Tank and lid for damage. Is the lint screen clogged? Make sure the lint screen is in place on the tank lid and not placed into the motor duct. Also, clear the holes on the lint screen.
7) Check to see if the upholstery hose has suction. If the hose has suction and the floor nozzle does not, check the diverter valve to see if it opens and closes freely. This can be seen through the Floor Nozzle window as you switch the diverter knob from the floor to tools setting.
Aug 11, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
The bissell proheat will not suction
Jun 15, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No suction
Jun 15, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
My bissell will not **** up water
Please try the following suggestions to see if you can get your machine suctioning properly:
May 19, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
Fllor nozzle window blockage
take the 2 screws out near the front outside edges then just lift it off
Jun 30, 2009 | Bissell 1699 ProHeat Clear View Upright...
How to clean
I have found this so i think this answers my question.
Question         How do I remove the clear floor nozzle window on my machine?     shim.gif     Answer         Before starting, please be sure the machine is not plugged in and the machine handle is reclined.
To remove the clear floor nozzle, first detach the phillips head screws located at the base of the clear floor nozzle. Then, remove the tank in tank assembly. Next, remove the rectangular gasket at the top of the nozzle, and pull the clear floor nozzle forward to remove the tabs from the notches. This clear floor nozzle is removable so you may be able to access this area and clean.
When putting the clear floor nozzle back in place, please be sure the tabs at the TOP of the nozzle are properly inserted into the notches provided. If you do not have the tabs in place properly, you may have a problem with the machine's suction.
Rotate the window down into place, replace the screws, and replace the rectangular gasket.
If you would like additional assistance, please contact BISSELL Consumer Services at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET or email us by clicking on the Email BISSELL tab at the top of this page.
Reminder: When you have completed the deep cleaning process, it is recommended to return the SmartMix dial to "Water Only" prior to storing the machine.     shim.gif     How well did this
Oct 10, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
46 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
