Question about Kyocera KM-1510 Copier
I have problem while copying with my kyocera mita km-1635
I add a new toner last day...then while copying, a black line appears at the back side of my copies..I read your product's user manual and try the cleaning procedure but the problem could not be solved...whole copying both side of a page, the dark line becomes darker....i am from india, and here i can not find support for this product..PLEASE HELP
  • SUBHASISH235 Aug 17, 2008
    my copier model no. is kyocera mita km-1635
  • innah
    innah Mar 04, 2014
    all you need to do is to call for maintenance of cleaning... same problem i encountered last time... but it was solved by cleaning
May be you are using the compatible toner. I do have the same machine. Unfortunately I used a compatible toner. Immediately the problem of Black lines appearing at the rear of the page started. I chaged the toner with the orginal one and the problem vanished. Try this solution and reply.
Posted on May 11, 2009
You are not using the right toner.
you may using compatible toner.
I have the same model copier. The same problem faced after I chages the toner with a compatible toner.
Posted on Apr 05, 2009
  • 417 Answers
If its on the rear side of the page would most likely to be the transfer unit. What model is the machine?
Thanks Jason
Posted on Aug 17, 2008
What make the buttons of my Kyocera Mita KM 1620 stop working
the buttons stop working because the internal pressing are crash and you should replace it or join it by welding. but first of all you may blow the panel it could be some dust.
Sep 18, 2014 | Kyocera Mita KM1620 Black Toner Cartridge...
How do I clean spilled toner from the inside of a Kyocera mita copier?
Try using a small soft brush to brush it off while using a good hepa filter vacuum to remove the toner at the same time. Wear a good breathing mask to protect your lungs!
Aug 06, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Add toner always show copy not print and ready
When the toner supply belt is broken or displace than toner not supply from the cartridge in the DV unit.You shuld check this drive section and replace new one.I wish best luck.
Oct 26, 2013 | Kyocera Mita KM-4035 Printer
Kyocera mita km-1820 not printing clear copies
you have to check the duplex unit on the machine itself.
May 01, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Apr 15, 2009 | Kyocera KM-1505 Copier
UNKNOWN CODE
when ap code is coming add toner. when the toner is empty this code displays.
Nov 23, 2008 | Kyocera Mita KMR-1810P Laser Printer
Kyocera KM-1510 Copier Logo
504 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
