No sound on my reciever
I have a yamaha rx v590, i installed 8 speakers on it, it dint produce any sound, and when i tried the normal one, 6 speakers, it dint work no more, but it hs power. can you help me on that? do you have any solutions?
    Genius:
  • 1,550 Answers
The audio amplifier IC of your device are damaged need to be replaced.
Posted on Aug 17, 2008
My right channel is weak. universally. any effect mode and speaker a and b . Seems slightly stronger when balance knob is at center but is still nearly inaudible . Is it the balance pot or a circuit or a...
I have seen this a lot of time on Yamahas, one of the channels are either a bit or a lot softer than the other, this happens after warrenty and you need to have it repaired.
Oct 08, 2013 | Yamaha Rx-v590 5.1 Channel 265w Natural...
How to connect Niles #SSVC-6 Speaker Selector to Yamaha RX-V671
Greg, It pretty basic hookup,Just hook it up to your speaker terminal on the reciever or amp.To the input of the (Speaker) Selector.
Oct 04, 2012 | Yamaha RX-V671
Where are the preout connections
Right between the speaker connections and the AC convenience outlets on the rear.
Dec 23, 2010 | Yamaha RX-V590
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
My reciever has no sound. everything else still works but it just won't put out any sound at all. yamaha RX-V863 7.1 channel. less than 6 months old.
Check your "A/B" speaker selector switch on the front panel of the receiver, if they are on, you will see "A" "B" or"AB" on the front display. If they are on, You need to have the receiver serviced. Just a note, Yamaha's rarely have an output problem! Hope this helps
Jan 09, 2010 | Yamaha RX-V863 Receiver
Can I hook up an ipod to a Yahama RX-V590 receeiver?
Yes you can. You need to buy an auxillary cable for your iPod that converts the 3.5mm jack to regular RCA audio jacks. Then connect the RCA audio jacks to the jack of your RXV590.
I hope this helps. Thanks and have a nice day.
- HotRatchet
Dec 14, 2009 | Yamaha RX-V590
Pushing 4 ohm speaker systems
Officially this receiver supports only 6 and 8 ohm speakers. But for surround speakers it should not do any harm, because they are not played at full volume. But be sure to set yamaha for 6 ohm speakers.
Using only 4 ohm speakers makes the amplifier work more hard and produce more heat, that's why you can't use it at high volume.
Nov 30, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
When my volume is set above a certain level it shorts and it isn't set high at all.  It is a yamaha rx-v590 receiver, any idea of the issue?
A speaker wire or a speaker may be shorted.
If the positive wire is touching the ground wire anywhere in your system, this will occur.
Run the speaker "test" to hear all speakers. If one does not sound off, that is probably your shorted wire our bad speaker. Check for a bad splice, back of receiver speaker output, speaker input, or wire shorted on tack strip under carpet,etc.
If this does not help, you may have a shorted speaker channel in the receiver itself.
This goes for most all receivers that are not vintage in age.
Oct 25, 2009 | Yamaha RX-V590
Yahama RX-V590
Sorry to have to tell you but that means there is a short in the output circuit or the power supply. I would bet that one or more of the output componets are bad. If you know solid state circuit troubleshooting, It still may be worth repairing. if you do not then most likly it is time to get a new unit.
Oct 14, 2006 | Yamaha RX-V590
66 people viewed this question
 Grubhead
Grubhead
