Simpson esprit 600 washing machine
Washing machine only agitates 1 way. wont lock in and agitate in opposite direction
  • 185 Answers
SOURCE: simpson esprit washing machine
put a new pressure switch in it
Posted on Mar 26, 2008
Maytag317
  • 1136 Answers
SOURCE: agitator making clicking noise when washing clothes; clothes wrapping around agitator
If this a whirlpool brand washer, there are sone parts bad in the agitator it's self. These parts are called dogs and they make the agitator rachet so that the top half only goes one direction. Does this sound like what you are experiencing? If so, let me know and I can assist you further.
Thanks
Vic
Posted on May 13, 2009
SOURCE: Simpson Esprit 650 6.5kg Washing
I have just had the same problem occur with my washer.
I found that the hot would work but the cold would not.
The fault is the cold water valve.
This is the part that the hose screws to at the back of the machine.
To have a look at it unscrew the top of the controls at the back and you will
find the valve.
Follow this link for the part.
http://www.alliedappliance.com.au/info/A864810001.html
Posted on May 21, 2009
SOURCE: Simpson esprit 550.The agitator is not moving in
Had the same problem with mine, could be a number of things but in my case it was a relatively simple fix - but you'll need to buy a part.
Open the lid and look inside, the bit sticking up in the middle of the machine is called the agitator. Remove all the fabric softner and lint filter from it and you'll see one very small bolt at the base.
I concocted a number of ratches stuck together to reach it but once undone you can pull the enitre agitator up an remove it.
The agitator is driven by metal bolt with teeth at the bottom of the tub, however the agitator itself is made entirley of plastic, therefore (prob due to age) the metal teeth had eaten away the inside of the agitator and so it was just spinning inside its hole!
eplace the agitator and problem solved.
Posted on Dec 06, 2009
SOURCE: Simpson Esprit 650 - Won't agitate
Our machine , same model, was doing the same. Had a repairman cone out & it was the Motor Control unit, seems to be a fairly common problem. But now its fixed & working well.
Posted on Jan 14, 2010
How to remove agitator from Simpson 750 esprit
Look down inside the agitator. At the bottom is a hexagonal bolt. You need a 10mm socket on a long extension bar to reach it and undo it. Then pull agitator up & out.
Feb 15, 2017 | Simpson Washing Machines
Hi, we have Simpson top loading washing machine model number Esprit 550, the drum is not rotating and the spinning plastic rod in the centre of the drum is not spinning/rotating either
that is a direct drive
is the agitator (plastic rod )loose or sloppy
if you look down the inside of the agitator
do you see a nut at the base holding the agitator tight
if the timer is working
and water can pump in and out
that is good
bad
if you cant hear the motor click in
it will need to have the inspection cover taken off
for service or part replacement
May 20, 2016 | Simpson Washing Machines
SImpson Esprit 550 wont agitate or spin
programmer , drive belt or controller may be faulty. any codes please? Might be the motor also
Jul 10, 2015 | Simpson Washing Machines
I have a Simpson esprit 550 and it won't agitate or spin? Fills and drains fine any help would be great thanks
check pressour switch door lock or lid lock not familer with mechine so don't no if its top or front loader good luck
Apr 20, 2015 | Simpson Washing Machines
Simpson esprit 550 agitator & spin not working properly.
Open the lid during the wash cycle and observe the agitation, you need to see exactly whats happening, If its corkscrewing instead of agitating it will wind the clothes as you described. Agitation is usually back and forth, or up and down etc, not just turning constantly in the same direction.
Aug 25, 2014 | Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Simpson esprit 450 Agitator only turns one way causing load to wrap around agitator. I've removed agitator and nothing is caught up. Wondering?
Inside the agitator there may be a circular section that has 4 small tabs with small teeth on them, if this has these, inspect each tab to see if the teeth are wore, ifr so replace the teeth. They are called "dogs"
Mar 31, 2012 | Washing Machines
Dec 27, 2009 | Washing Machines
My simpson esprit 600 is not agitating during wash cycle it only goes one way
Im having troubles with mine. Just not sure what to replace..
The wash cycle is fine however when it comes to drain and spin cycle, the water doesnt drain. It does make a noise during this cycle but im not sure whether the drain pump need replacing or the drain pump motor?
Can anybody help?
Aug 18, 2008 | Washing Machines
Washing Machines Logo
313 people viewed this question
Top Washing Machines Experts
