I have a Fujitsu Plasmavision P42VHA20AS. The screen displays what looks like a paling fence (of lines) with the pic behind it. You have to turn the TV on and off several times to lessen the effect however it never goes away completely. I have contacted Fujitsu in Australia and they have been of no help at all. Can you help me please.
  • maggilla Aug 27, 2008
    Hi all
    I have this model Fujitsu in for repair .On Av3 S video and RGB pic is perfect but on Av1 , Av4 the pic has a venetion blind effect
    the effect is horizontal and vertical I have also been to deleted items but found no relevent faults
    any ideas
Found the problem with this unit fault .Fine patterning lines Vertical and horizontal over pic. This patterning for us was only apparent on Av1 and Av4 ..AV2 /3 and rgb were ok .Problem is Dry joints on the Earth contacts main digital ic .If you use to much solder you won't be able to refit the IC cover .Don't remove ic SEE pic.
Link to pic: http://ceta.org.au/pipermail/cinlist_ceta.org.au/attachments/20080710/cfcaea09/attachment-0001.jpe
Cheers
Posted on Aug 27, 2008
  • mymps3 Dec 27, 2010
    The link to the pic is missing. Where is the link??
Is 9 year old Fujitsu Plasmavision TV worth fixing?
Hi
Can i please know yout TV model number to assist you better.
Thanx
Jul 22, 2010 | Fujitsu Plasmavision 42" TV
Tip
Drivers for Fujitsu Plasmavision 42" Display
At http://www.plasmavision.com/tech_faq.htm the following answer is not exactly true:
Q: I'm running Windows XP on my Plasmavision display. Can you please send
me, or tell me where I can download, the video drivers for this model?
A: Video drivers are part of the video card installed in your computer, rather than the monitor showing the computer's images. Please check with your video card manufacturer. All Fujitsu displays are Plug-N-Play devices, so there are no drivers available.
For the PDS4203-WH circa 1999, there was an optional video card based on an S-3 ViRGE chipset that allowed you to connect your computer to the display and get the best use of the 852 (H) x 480 (V) display. Without this, almost all video cards fail to display fonts so that they are perfectly legible, which can be quite problematic, lol. Hopefully, this problem was resolved in later models, and they truly are Plug n Play.
Back in the day, this was a great monitor for playing video games. Outcast, from Infogrames, was gorgeous.
on Sep 20, 2010 | Fujitsu Plasmavision 42" TV
My 50' 2005 fujitsu plasma starts with a few flickering lines and within a few minutes the whole screen is covered is horizontal lines - any ideas?
It sounds to me as though you have a faulty Digital board which can be repaired by Fujitsu.
Please call 0208 731 3432 for further help if needed.
Brads
Jun 10, 2010 | Fujitsu Siemens Plasmavision P55XHA30 55...
Error Message: Condition 1
Error condition 1 is a faulty Fan. On these units if one fan is faulty then the sensor will shut the screen down as a protection.
a repair of this unit is possible.
Regards
May 12, 2010 | Fujitsu Plasmavision PDS-4214 42 in....
I need to change the aspect ratio on the fijitsu plasmavision - everyone looks fat. how do i do this?
Press the "WIDE" pushbutton on the remote (or on the display front panel) to change the screen aspect ratio.
There are also adjustments to picture size available via the on screen 'Menu' , 'Size' selection. When in this mode, use the navigation arrow keys to alter the screen size. Press centre 'enter' to store selection.
Apr 10, 2010 | Fujitsu Plasmavision P42HHA10 42 in....
Have a fujitsu pds4229w-s it Have Have a fujitsu pds4229w-s it Have a fujitsu pds4229w-s it turns on and then have a fujitsu pds4229w-s it turns on and then when you put the video source to it its ok then...
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 09, 2017 | Fujitsu Plasmavision PDS-4229 42 in....
My fujitju 42 plasmavision purchased from Harvey Norman less than a year ago has a shiny blotchy area on the screen that wont wipe off.
Look carefully:Is this just behind the glass front? If so, somebody or something has leaned very heavily against the screen bending it inwards and fracturing the display layer. If no obvious signs of impact damage, spillage, corrosive sprays etc, try your warranty.
Jan 22, 2010 | Fujitsu Plasmavision P42VCA30EH 42 in....
How do i set up my nintendo wii to a fujistu plasmavision
http://www.plasmavision.com/Plasma_PDF/OMP50XHA(42VHHA)Home.pdf this is the users manual for your componant under usage refer to connecting external equipment to display thanks for stopping bye at fixya!
Jan 01, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Fujitsu p42hha30ws
Black vertical line indicates horizontal deflection section not working. Change horizontal linearity coil the problem is fixed
Jul 24, 2008 | Fujitsu Plasmavision 42" TV
I'm looking for a Fujitsu Plasma TV repair company in the San Francisco area. I have a plasma tv screen which is shattered and I need to know if it can be repaired.
Hi Calif Lady,
For assistance locating a service center for Plasmavision, Fujitsu’s brand of plasma televisions, visit http://www.plasmavision.com/locate_serv_ctr.htm. This should populate a list of authorized service centers.
Otherwise, you may visit http://www.plasmavision.com/service_inquiry.htm to enter a specific inquiry.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 25, 2008 | Televison & Video
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
