Question about Fujitsu P42VHA30WS Television
Picture gets hung
Hi I need help ..my picture gets stuck on the plasma..when I use DVD or even cable channels
Rohini
rohinisuri6@gmail.com
  • 2,071 Answers
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Posted on Aug 17, 2008
My uninor sim got blocked and its askin for a puk code so pls give me da puk code.my mobile no is 8523871246
Rohini, please contact your service provider, this code is free given by customer care line by your network provider. no Technician can help you. so please kindly follow the sugestion. Thanks for visiting Fixya.com. If my answer was helpful please rate.
Jul 01, 2012 | Nokia X2 Mobile
I cannot get a picture on any channel. Not hooked to cable. No antenna. What is the problem?
Most of the TV sets have " Picture Mute" feature which means; if no signal exists on either Antenna plug or on Video input (RCA jack) no picture at all.Blank screen..no audio as well..all MUTED..
to test it ,play a DVD ,you must have pictures and audio together..
Use an antenna ( even a piece of plain cable will work ) ,and run "search" ,you must receive some TV channels thru AIR.
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Toshiba MD13N3 13 in. TV/DVD Combo
Hook up to dvd player
There are more than two methods of hooking up the DVD player.
1) Get a 5pin component cable with Red, Green & Blue pins. Connect the DVD Player's RGB out pins to the TV's RGB in socket. This will take care of the picture. Then for sound you will need the secondbobhifi_4.jpg set of Red & White cable. Connect the Red & White pins to the DVD players audio out socket (Red for right channel and White for Left channel ). The other end of the cable you can connect to the Red & White socket next to the RGB socket where you have connected the Video. Play a DVD and scroll through the inputs slowly. You will see the picture appear on one of your selections.
Mar 10, 2011 | Daewoo DP42SM 42 in. HD-Ready Plasma...
I bought a Sanyo DP46849, lcd tv, 1080. and I'm getting a fuzzy picture. It helps when i put my cable receiver on hd channels, but even my blu-ray looks better on my 720 plasma???? any suggestions, I...
I gather from the information given that you are getting the proper signal from the cable receiver but there may be a settings issue with the LCD TV. If the 720 plasma is giving good performance then it has to be settings on the lcd .
I would review the instruction manual to see if you have over look something that is a proper cable select ( hdmi or vga).
If you have selected vga you will not get a clear picture in that mode. HDMI is High definition which works properly with 1080P mode. If you have further issue the manufacturer troubleshooting or Knowledge base will give answers also.
1. check your HDMI cables make sure they are properly seated in the input ports
squarely not at an angle.
2. If you are using a cable receiver check the connection there. Make sure you have the proper cable for your receiver to the TV
3.check channel to see if you TV is selected for channel 3 or 4 as recommend in the instruction manual
4. check the V-chip setup it may be blocking certain channels
5. check you picture modes each channel can have desire picture setup modes.
6. If you are using rca cables you may not get the proper picture as you would with HDMI cable that are specially designed for High Definition TV
Mar 13, 2010 | Sanyo DP46849 46 in. HDTV
How do you connect AWA plasma TV to AWA surround sound
Hi Map33_bm
It appears that your TV set is 2 channel stereo, so as there is no surround signal coded into the TV audio channels, thesurround sound does not process it.
I've posted a PDF in 'manuals' which you can check out.
Did this info help at all?
Regards, Clive.
Oct 28, 2017 | Televison & Video
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Broksonic VCR
It should be either ch 3 or 4, BUT the VCR must be turned on and in the "vcr" mode. There may also be an way that you can switch between tuner and Video on the VCR, it would need to be in video mode.
Hope that helps...
Geno
Mar 26, 2008 | Televison & Video
No sound on some channels
Had same problem on Viera 3D Plasma TH-P54VT20A
Select Sound from setup menu and ensure SPDIF Selection is set to PCM (not Auto)
Feb 28, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Fujitsu P42VHA30WS Television Logo
336 people viewed this question
Top Fujitsu Televison & Video Experts
Tony
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
