Question about HP Office Equipment & Supplies
Colours not printing properly on all work, an also colours on the test patern not printing in the right places
  • 142 Answers
This sounds like you have a bad ink cartridge, either inkjet, or laser colour, whetever the case may be... Have you tried a new ink cartridge?
In both cases, laser and inkjet, the cartridge incorporates the print heads which may become clogged, or misaligned, or the ink/toner inside may be starting to dry up, or cartriges may be bad from the start.
Especially if this is a cartridge that has been refilled before, I'd try a new cartridge.
Some printers also offer a print head alignment check in the software included. I'm not sure if yours does or not since you did not specify model number.
Posted on Aug 17, 2008
    Genius:
  • 1,847 Answers
Reinstall the ink cartridge and then try
Why isn't my printer printing my picture?
Is it mac or windows based pc? Is the printer directly plugged in via USB cable, or is it a wireless network printer?
In most cases, if it was working as it now now. A simple computer restart can do the trick. If not, the other questions will help direct someone to the right place to look at the settings to make sure its properly being recognized by the computer
Nov 21, 2014 | Epson Office Equipment & Supplies
My pictures have lines in them and the color is not right
Your color cartridge is not printing out of every slot in the print head or you are out of one of the colors. Try printing a test patern. If you have the same problem with the test patern, change your color cartridge.
Mar 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Dell Monitor goes blank, green light still on.
Have you tried connecting that monitor to another PC. It sounds like you may have a problem with the monitor itself (component failure, heat problem, etc)
Nov 20, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Colour printing
If its a Canon printer try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 02, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printer not printing properly
When you changed the cartridges, the printer automatically prits a test / calibration page. This page must be placed in the scanner, then you have to press the "scan" key (the green one). It will calibrate an align the system. Then you'll be able to print.
May 03, 2008 | Office Equipment & Supplies
Printing incorrect colouring
plz check the color carts: are they inserted at the right place? If not, change them into the right place. Run the cleaning cycle 4 times to get the wrong ink out of the tube and nozzels.
If you have them at the right places print a test print by pressing ink button and selecting the test print.
Does it look good or do still have the diffrent colors?
Nov 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
Wonky colour printing!!
you need to run a print alignment test.. this should correct the colour faults (unless you really do have blocked cartridges,
Sep 27, 2007 | HP DeskJet 5550 InkJet Printer
Colour printing
If the test patterns are not matching what your printer tells you is normal and your photos are banded horizontally, you may have clogged nozzles and printhead. Do a maintenace clean under your printers direction, and see if it now prints ok. Also, you may be low or out of one particular colour, but still have enough of the others and the printer will try to compensate by using available colours, hence colour banding and distortion. A manual clean with cotton buds and cleansing solution is recommended if the first clean does not help.
Dec 12, 2006 | Canon BubbleJet i560 InkJet Printer
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
