I OWN A VRX775VD AND I GET AUDIO ONLY WHEN TRYING TO WATCH A DVD.
    Problem Solver:
  • 8 Answers
Are you getting a blue screen saying it is unlawful to view while in drive? if so it is against state laws to install an on/off switch in line with the green park break wire to a ground allowing you to click 3 times and confuse the radio to think its in park you should never do this its dangerous to you and every other driver on the road :)
Posted on Dec 24, 2009
  • 2,071 Answers
First try to change the cord maybe there is invisible breaks or cut inside the cable cord that you can't see.If ever you change already and still no picture ,then the problem is in the TV unit, the video connector is cracked or loose or cold solder joint.Just re works the solder of the audio / video connector section,so its works normal again.You can do it yourself or find a good technician to do works for you...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 17, 2008
    Brigadier General:
  • 6,966 Answers
Hi again,
For some reason, I could no longer post a response back at the Live Session/Chat. Our apologies for any inconvenience.
Nonetheless, with your indulgence I will continue posting here.
There would be two possible reasons why there would be no video on a Clarion VRX775VD.
the first would be the video interface which simply is like the video card of your computer. This rarely go bad but if suspected would require that the unit be removed from the vehicle's dash and repair works carried out on a workbench.
The second would be the backlight. You can actually verify this by playing a video DVD/VCD preferably at night and with a flashlight, shine a light on the screen. If you see semblance of the movie, then you have just confirmed it to be a bachlight issue.
Backlight could then further be wither the CCF lamps (cold cathode florescent) or the inverter. The CCF lamps are similar to the long thin lamps used in laptop displays. The inverter on the other hand is a PCB that houses the component that converts your car's 12VDC into a high voltage high frequency power that supplies the CCF.
All of course require the services of a qualified professional. If you are considering a DIY (do-it-yourself), pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
42in insignia tv im trying to watch a movie and there is no sound how do i get it on
Try going into the Audio Settings and set the digital audio to PCM.
If the movie you are trying to watch is the only movie this happens with, try pressing the audio button on the DVD remote to change the audio stream.
You should also set yout DVD players audio output to PCM as well.
Hope this helps!
Feb 15, 2010 | Insignia LCDTV26 26 in. Television
I dont get the sound, can see pictures.
hey sajith,
check all the audio and video cable's connected to tv and dvd player.
you may have forgot the wire color's (audio and video) there would be one wire for video and two for audio. some times there would be a RF socket also. so, see the right sockets and connect to tv by interchanging wires.
Dec 29, 2009 | Sony DVP-NS575P DVD Player
I have a clarion in dash dvd player I want to know if I can use any tv tuner for it or if I need a certain one
If you want to be able to use your remote, and touch screen functions for the tuner then you need to buy the clarion tuner to match. If you dont mind having a seperate remote tocontrol you stations, then you can use any brand. If you are buying off the web, be sure it is a Dtv converter, and not an analog tuner, or you won't get any stations.( Lots of people are trying to unload old out dated analog tuners on the web, so be careful)
Aug 08, 2009 | Clarion VRX775VD Car Video Player
I cant find the Part Number for the connector harness that has th
You will have your best luck at a local car audio shop that sells clarion. If your not sure where to find one, you can do a dealer search at Clarion's web site. www clarion.com Hope this helps
Jul 08, 2009 | Clarion VRX775VD Recorder
Clarion vrx775vd video problems
Does the video work if you pull your ebrake up, then there is a wire mounted to ebrake that you need to mount to something else so you can see video all the time, when a place installs a in dash dvd they have to put wire on the ebrake to prevent people from watching it while they are driving
Jan 17, 2009 | Clarion VRX775VD Car Video Player
Clarion 756vd
You should contact Service Center as this maybe because of any other problem as well.
Aug 03, 2008 | Clarion VRX775VD Recorder
Sony dvd surround sound
dvd sound cuts in and out while trying to watch a dvd at a moderate sound level
Jun 29, 2008 | Audio Players & Recorders
Dvd player
Are you trying to watch the dvd while your driving? Depending on who hooked up the radio the DVD receiver is only supposed to come on when the emergency brake is engaged. You may have to hook it up another way for it to play while your riding.
Mar 25, 2008 | Car Audio & Video
Clarion vrx775vd
That is pretty vague. More specific would help, but if you go to Clarion's web site they have the manual on-line.
Feb 17, 2008 | Clarion VRX775VD Recorder
54 people viewed this question
 Grubhead
Grubhead
