Simpson Genesis 511, the agitator not working in wash cycle
  • Anonymous Feb 17, 2009
    only spins 1 way.
  • ian9890n61 Mar 18, 2009
    Agitator only works one way, most of the time.
  • 1294 Answers
SOURCE: My washing machine is not draining
You can try this: It's for the Kenmore/Whirlpool models..
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels, a good big plastic bag or a wet vac to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Posted on Apr 03, 2009
SOURCE: simpson genesis 525 washing machine
leaks from underneath
Posted on Jan 15, 2010
  • 867 Answers
SOURCE: How do you remove the
Remove the link trap/Fabric Softener dispenser from the middle. You will then need a 10mm Socket and a long extension (or 2), undo the bolt in the bottom an the give the agitator a good pull (they can be REALLY tight) if the agitator still won't move put some really hot water into the machine until it covers where the bolt is/was and leave for 5 mins then try again.
Posted on Oct 25, 2010
e-Guru
  • 3917 Answers
SOURCE: how to repair the bearings
Hi
Please check the bellow link related to drum bearings:-
http://www.washerhelp.co.uk/diy-repair-help_2.html#cl_q4
Also follow the easy steps:-
1) Disconnect from the power, water etc. and find some space;
2) Remove the lid (two screws at back of machine) and the back panel. I also took off the concrete weight on top to give myself some more room and less weight to move;
3) Remove the fan belt;
4) Unscrew the bolt on the end of the drive shaft. This holds the pulley in place;
5) The pulley is pushed on to a V-bushing. It may be very hard to get off. The easiest way was to put a large screwdriver behind the pulley hub and the 'spider' bracket behind. Then use leverage to pop it off. The V-bushing should then slide off the shaft;
6) Remove the three bolts that hold the ends of the spider to the drum. I found these very hard to get moving and they are also awkwardly placed. Use a socket set and you may need a bit of rust-remover/degreaser.
7) Remove the three bolts holding the central part of the spider to the drum;
8) Tap the end of the drive shaft with a hammer while pulling on the spider. The whole spider and the bearings should slide off the shaft;
9) The spider holds two bearings (one next to the drum and one next to the pulley). I'd recommend replacing both. Apparently in most cases it is the bearing closest to the drum that gets damaged usually due to water leaking through the drive-shaft seal. The two bearings are different in sizes. When ordering replacements, I'd recommend rubber sealed 'RS' bearings. There is also a shaft seal that sits between the larger bearing and the tub. The seal comes from Simpson ($25). The bearing can be bought from any bearing supply company and are about half the cost of the 'official' bearings, and probably better quality.
10) Knock out the old bearings. The correct way to do this is with bearing pullers etc, but I used a long steel rod (one of the transports locking rods that new machine's come with) and a hammer (not even rubber). First knock out the large bearing and the drive shaft seal by inserting the rod through from the other bearing side and hit firmly while alternating the position of the force around the case of the bearing. I propped the spider against a brick to ensure the bearing and seal could pop out freely. Now turn around and repeat for the other bearing;
11) Clean up the spider and shaft, ensuring you remove any rust and debris;
12) Tap the new bearings into place. Again I used a hammer and firm tapping around the ring of the bearing;
13) Tap in the new drive shaft seal;
14) Reassemble.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 21, 2011
mc1bean
  • 3053 Answers
SOURCE: how to get my simpson 511 agitator to turn on ?
Hello, collier
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Nov 03, 2011
Simpson enduro 501 wont agitate. Everything except the Wash cycle works...
check the cam dogs in agitator and check the water pressure switch with a meter it controls when machine goes into wash cycle
Feb 04, 2015 | Simpson Washing Machines
Simpson agitator
This is usually caused by a faulty capacitor failing that a broken cluth pawl
Sep 26, 2017 | Simpson Washing Machines
Simpson agitator
I have the same problem, seems as if this washer always tangles the clothes, there is really no solution.
Aug 25, 2014 | Simpson Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
How do you remove the agitator from a Simpson Genesis 505 washing machine
Oct 24, 2010 | Washing Machines
Washing Machines Logo
400 people viewed this question
Top Washing Machines Experts
