Question about Nintendo DS Console
Nds lite doesnt power off
I have a Nintendo ds lite, suddonly while i was playin it on charge (yes thats right i was playin it while it was on charge, so theres no way it can be flat) it turned off.......so ooo i tried to turn the ds on again, it went on for about a second then turned off again.
At last from all these times from turning it on it stayed on !!! I tried to turn the nds off again but it wouldnt turn off, i tried a million times to turn it off but it just wouldnt turn off. I took the batery out and put it back in which restarted the system, i turned the nds on again, it Worked, i thought it was fixed !!! UNTIL i tried to turn it off again, it still wont turn off !!!!!
so i decided to play my r4ds, ( will the r4ds have anything to do with it???)
while i was playing Worms: Open Warfare 2 the nds turned off again....WTF?? And now evry now and get it turns off automatically while playing a game, But i still CAN'T Turn it off by the power Switch!!!!
PLEASE HELP ME
Email me [email protected] or
just post it reply on FIXYA
  • Anonymous Sep 03, 2008
    My nintendo ds only stays on for a few minutes,then goes off,its full of charge,any help would be appreciated,thanks Marjie
Dear Cornjo,
Your situation has baffled me completly. Here are some solutions that might help you:
  • How old is your DS/DS Lite? If it is less than 1 year old or if you have a gurantee for more than 1 year, you can take it back to the shop.
  • Try taking out the battery and not putting it back for at least 24 hours
  • Charge your DS COMPLETLY and do not use it for a while
From Andrei S.
Posted on Sep 20, 2008
SOURCE:
Ds lite is reading system date error
Known problem with the NDS Cards but here is a temporary fix:Take out the NDS cards and start up DS without them
  • Tap the symbol in the middle of the screen at the bottom that looks like a DS.
  • Tap the blue box with a calender and clock in.
  • Change the date a month or two back.
  • Restart DS with NDS cards in.
Even though this is temporary the people at NDS are working for a solution. But until then you might just have to keep putting the date back.
Apr 15, 2010 | Nintendo DS Lite
Nintendo ds lite; left and right buttons stopped functioning. Is there a reset for them or a way to correct the problem?
maybe you are playing too hard...i think the rubber inside is damage..try to check it out and replace it if posible..but be sure that the one who will open your nds is a lisence tech. for nds..ok..
Feb 19, 2010 | Nintendo DS Lite
Nds lite wont turn on
if you have another nds lite try switching batterys if that dont work then its broke, sorry.
Sep 21, 2009 | Nintendo FOR NINTENDO DS LITE NDS AIRFOAM...
Ds doesnt charge or turn on
The NDS enters the sleep mode abruptly
1.It is possible that external magnetism causes the system to enter in sleep mode .Therefore ,keep the system away from nearby magnetic objects
Jul 20, 2009 | Nintendo DS Lite Console
My son nintendo ds lite does not go on when he lift the power on.
Okay I think I know what you have maybe your nds is bricked a bricked concle is the firmware got corruped or delited off of the mother bord
Apr 07, 2009 | Nintendo DS Lite Console
Ds lite not working
i had same problem ( bought a faulty nds off ebay and would charge but nothing when powering up, not even a blink of green light) problem is a component called a L2 its an inductor 33uH in case SMD 1007. its situated dirrectly under the power switch but they are prone to fall off when nds is dropped ect. you need to resolder it on (very tricky). give your nds a shake to see if you can hear it rattelling about. be carefull when opening your nds not to lose the part (its very small, about 4mm long 2mm wide) GOOD LUCK
Jan 05, 2009 | Nintendo DS Lite Console
My DS power
How long have you had that battery in your DS? The more you use (play and charge) the battery, the battery's capacity is decreased. Try getting a new battery at,
usg.html">http://www.calcellular.com/ntd-ba-usg.html (for DS lite)
or
nds.html">http://www.calcellular.com/ntd-ba-nds.html (for DS).
Your welcome
Dec 29, 2008 | Nintendo DS Lite Console
NDS Lite will not turn on
I hear about the ribbon cable not being inserted wel.
Lots of people had it put in place, looking ok but no action from the ds. I suggest to reinsert the ribon cables, i heard its quite tricky with the ds...
Apr 10, 2008 | Nintendo DS Lite Console
Nintendo DS Lite shuts off randomly.
I'm a certified electronic technician and I must say NDS internal screen ribbon connectors are junk! Basically The ribbon connectors are so sketchy that it is not recommended to ever unclip them, if you do there's a good chance it will ever work again once reconnected due to how the connector pins slightly crimp into the ribbon pads.
When a NDS boots up the the onboard firmware constantly tests the LCD screen connections, if there is a break in the connection the NDS will shut down. If your NDS randomly turns off, fails to boot, or powers of when you move the hinge it is most likely the ribbon (flex film) or ribbon connector has failed. The only option to to replace the affected LCD screen.
Jan 08, 2008 | Nintendo DS Lite Console
Nintendo ds
To guest. Maybe something wrong with battery. Does this problem persist when your nds is charging?
Nov 25, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
153 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
