Question about Furuno FCV-582L GPS Receiver
Trying to wire nav man gps imput into a 585fcv furuno echo sounder,i no the white wire of the nav man nmea output ,but what coulour wire is the imput for the 585,white and blue.but which one is the signal wire and which one is the earth,cheers Rod
    New Friend:
  • 132 Answers
White and blue is correct, white is signal, but be aware that manufacturers screw this up all the time, so try it both ways, and look for pulsing data on digital meter measuring 12V, should see meter jump rhythmically, from 0 to 4-12V. Confirm presence of data to maintain sanity
Posted on Jan 16, 2010
Can i use a gps30 with 1715 furuno
You can interface the GP30 to the 1715 and get Lat/Lon readings where the cursor is. The GPS has extra wires in the power cable. The 1715 will require a NMEA cable pn 000-154-028. Connect the white GPS wire to the yellow radar wire and the blue GPS wire to the green radar wire.
Feb 24, 2014 | Furuno GPS
Connection to PC for Nav software
Assuming you have GPS input to your 1732 (i.e. GP310/320 sensor), you'll need a 7 pin NMEA data cable (000-154-028) wired to a D-sub 9 pin (serial) plug. The shield goes to pin 5, blue to #3, & white to #2. Jumper pins 7 & 8 together. The 7 pin cable goes to Data port 3 of the 1732.
Jul 12, 2010 | Furuno Navnet 1732 GPS Receiver
How do i connect my furuno navnet vx2 to my vhf radio. i have a 6 pin nmea cable for the vx2. but i do not unerstand which wire to use.
the output is on the black (blue) and white wires. in system setup, portsetup, you can select which sentences it sends out. 847-746-0100
Jun 17, 2010 | Furuno NavNet vx2 GP1720C GPS Receiver
I have bought a ICOM VHF m601 and I want to connect the furuno gps 31 to the VHF. Is this possible ?
Using the nmea output from your GP-31 to the nmea input on the VHF. Enable the GLL Sentence and make sure the port is set for nmea0183. Remember hooking nmea up it's positive to positive and neg to neg. Once that is done and you have a fix you should have lat and long on your vhf.
Mar 09, 2010 | Furuno GP31 GPS Receiver
How connect the nav net vx2 to autopilot simrad.what output port and colour cable
Get someone from a marine electronics company to do this for you. If you are unsure of the basics of what you need and you attempt to do this while going in blind, you may ruin your nmea ports on your navnet and autopilot. While I understand that you are trying to save $$$ by doing this, there's more to it than just wiring. There are port setups and nmea sentences to enable etc.
Jan 18, 2010 | Furuno NavNet vx2 GP1720C GPS Receiver
Adapt 997c si gps to navnet furuno sounder
no can do you must have a Furuno GPS or a GPS with NMEA 0183 output. you could get that from the Hummingbird display but not straight from the antenna
Feb 27, 2009 | Furuno NavNet vx2 1920C GPS Receiver
I have a furuno fcv 585 echo sounder with a FURUNO CA50/200-12M -c13298 BRONZE THRU HULL HIGH PERFORMANCE TRANSDUCER. The transducer has 4 wires and it looks from the schematic that it attaches via a...
you need an MB1100 matching box has the 10 pin pigtail for your sounder and accepts bare wire input from your ducer
this will also ensure that all power from sonar get to ducer, but it from me if you like 847-746-0100
Jul 09, 2008 | Furuno FCV-582L GPS Receiver
Navnet 500
I have been doing some research and I haven’t been able to determine if the Garmin has a compatible output for your Furuno. I can not recommend any service center particularly since I have no idea where you are located, but any good marine shop should be able to help you.
The Furuno uses NMEA Inputs for the GPS, and like I said I haven’t been able to determine if that Garmin uses that as an output. I would suggest that you inspect your installation to determine if there are any cableing between the two units. If no wires connect the two that you can be sure that the units are not communicating.
As far as the chartplotter goes you can buy data cards for them, either on-line or from a good marine supply store.
Apr 03, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno FCV-582L GPS Receiver Logo
195 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
