Question about Nokia N72 Cellular Phone
Removel of old battery from my nokia n-72
How do i remove the old battery from my nokia n-72?
Yhank you
Posted on Aug 27, 2008
Yhank you
    Problem Solver:
  • 19 Answers
Firstly u switch off the fone and remove the flap cover on back . Then simple , remove and replace a replace a new one
Posted on Aug 17, 2008
Ultralite 355 battery removel
how do i get to the battery onn z11
Jul 07, 2013 | Health & Beauty
I connected my nokia n72 to computer for software update..but its now not working and on the screen its showing as local mode..what can i do now
In my experience in N 72 this problem does not cause. So, try this ,....remove battery and press the power button by reinsert the battery.Because after we flash phone automatically it will change the phone mode to local/test.Even if there is no effect contact mobile repairing shop.Good luck
Sep 18, 2011 | Nokia N72 Cellular Phone
I m forget my imei no (Nokia N72) please gave my imei no
if u have ur nokia n 72 with u means just switch off it and remove battery and see beside it sure u will get the imei number for sure k
May 12, 2011 | Computers & Internet
N 72 WHITE SEREEN
Possible that the phone has a corrupt sofftware. remove off the battery and memory card, replace after sometime the battery and switch on. if the fault stays then you might have to reinstall the software.
Sep 24, 2010 | Nokia N70 Cellular Phone
Alternator removel on a 95 mitsubishi diamante
3.0 SOHC. TURN OFF RADIO. THEN DISCONNECT BATTERY NEGATIVE CABLE.REMOVE AIR CLEANER ASSEMBLY.LOOSEN THE TENSIONER PULLEY.REMOVE ALTERNATOR DRIVE BELT .REMOVE ACCELERATOR CABLE.REMOVE.BRAKE BOOSTER VACUUM HOSE.REMOVE EGR VALVE.REMOVE ALTERNATOR ELECTRICAL CONNECTORS. THEN REMOVE MOUNTING BOLTS THEN REMOVE ALTERNATOR. THE 3.0 DOHC DISCONNECT NEGATIVE BATTERY CABLE.REMOVE SURGE TANK.REMOVE AIR DELIVERY HOSES TO GAIN ACCESS TO THE ALTERNATOR .IF YOU HAVE AIR CONDITIONER .REMOVE THE CLAMP .RAISE THE SUCTION HOSE.USE SOMETHING TO HOLD IT OUT OF THE WAY.LOOSEN TENSIONER PULLEY .AND REMOVE THE ALTERNATOR DRIVE BELT .DISCONNECT THE OXYGEN SENSOR CONNECTOR .DISCONNECT THE ALTERNATOR ELECTRICAL CONNECTORS.REMOVE ALTERNATOR BRACKETS AND MOUNTING BOLTS .REMOVE THE BRACKET AND ALTERNATOR AS A ASSEMBLY.SEPARATE THEM ON A WORK TABLE.
Jul 05, 2009 | 1992 Mitsubishi Diamante
Battery removel 650 dragstar classic 1989
Battery is either behind one of your sidepanels or under your seat. Start w/ panels then seat. Remove cables from battery and remove...reinstall...good Luck to you friend..Tim
May 01, 2009 | 2005 Yamaha YZF-R1
Sterling collum is stuck trying to remove the keyclindor replac
there is a small hole on the cylinder use a pick and push the lock up at the same time turn the key and just pull.
Apr 05, 2009 | 1998 Nissan Altima
Forget Nokia N72 Memory Password
I forget my nokia n 72 memory password. How can remove password. Pls help me
Oct 26, 2008 | Nokia N70 Cellular Phone
Removel of setting wizard
try checking your service providers support section for downloads etc.
Dec 06, 2007 | Nokia 6600
Nokia N72 Cellular Phone Logo
76 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
