Question about Nokia 6610
Nokia 6610i Display not working
Mobile works fine (can make calls, receive calls, dial numbers and call too) except that the display shows up nothin... the lcd glows with a bluish light..
  • Anonymous Nov 28, 2008
    display
  • Anonymous Jan 18, 2009
    hello i have the same problem...
    the display used to work properly when i shake it after a day or so it again happens show blank screen
6610 i lcd problem
Posted on Feb 05, 2009
Sqdsqd sdsq dqsdsq d
Posted on Aug 23, 2008
  • salmansha580 Dec 12, 2010
    thanks it really worked
  • 199 Answers
Then your Lcd is broke, phone works fine, you just have to replace your lcd
Posted on Aug 17, 2008
Nokia 6610i imei not found
The IMEI number is unique the each mobile/cell phone.The number is printed on the label under the battery.You can also get the IMEI number by entering this onyour phone *#06# It will then display your IMEI number andyou may also get a unique global serial number. Your IMEI number should be 15digits.
Aug 01, 2012 | Nokia 6610i Cellular Phone
Tip
Nokia phones secret codes
Here are the secret codes of nokia mobile phones and will work on most of the latest nokia mobile sets. You can display the hidden information of mobile sets and troubleshoot the routine problems using these codes.
Follow the list of latest nokia codes list:
Code : Action
*#7780# : To restore the factory settings of mobile set
*#3283# :To verify the set Manufacturing date
*#746025625#: To stop the sim clock
*#67705646# :Use to delete the operator logo
*#73# :Use to reset game scores and phone timers
*#0000# : Use to display the mobile software version
*#06# : To display the IMEI Number of the mobile
*#92702689# :
To display the mobile warranty related settings
*#7760# : To display the Production serial number
*#bta0# : Use to display Bluetooth MAC address
*#9999# : Use to display the mobile software version
*#147# : If you are using Vodafone then this code will help you show the last call detail
*#2640# : To display the mobile security code
*#7328748263373738# : Apply to resets the set default security code
*#43# : To verify the call waiting status
*#2820# : To verify the Bluetooth information
*#7370# : To format the mobile phone memory
*#delset# : To delete the GPRS AND EMAIL settings
#pw+1234567890+1# : To display the lock status of mobile set
#pw+1234567890+4# : To display the lock status of your SIM
on Jul 07, 2010 | Cell Phones
Front display not working
There are two ways to cause this... the first one is malfunction of small lcd and the second is damage of main strip (pata).So, to fix this you need to contact mobile repairing shop.Thanks for visiting fixya
Mar 08, 2012 | Nokia 9500 Communicator
Nokia e71 blank screen
If the phone is working good without showing any display on the screen , the first step is change another LCD and if the problem still persist contact mobile repairing shop to change the display IC or check it out all the display related components.Good luck
Feb 01, 2012 | Nokia E71 Smartphone
I have bought Nokia E63 mobile. I have saved all the contacts from my sim card to my mobile, but while receiving the incoming calls the names are not displayed in the mobile and only the mobile numbers are...
The problem here would be duplicate contacts. When a call comes it searches the number in the Phone and SIM and displays the name pointing to that. Here in your case I suppose the same contact with the same number would be entered twice ( SIM + Phone) and phone gets confused which name to display and it shows just the number instead of name.
To solve this what you can try is to disable the SIM contacts from displaying. To do that go to Menu>Contacts>Options>Settings>Contacts> Contacts to display - Select Phone Memory only.
Hope this helps. Good Luck. ~SmokinJoe~
Apr 28, 2011 | Nokia E63 Cell Phone
When i switch on my nokia n72 it shows only a white display....help me
The white display indicates that there is some problem in the LCD display of the mobile. If the mobile works and display only not working means, it ensures the LCD display is got damaged.
Some times white display happens due to firmware corrupt also. in that case mobile will not work you can confirm it by making call during mobile is switch on. If so update firmware.
Dec 23, 2010 | Nokia N72 Cellular Phone
I have a Nokia 5310 and the screen is blank! but i can make calls and receive except i cant see what numbers i dial! what do i do?
change the display .if the warranty period is not over you will get it changed without any payment other wise you need to pay for the screen. so rush to the nokia customercare.
Nov 14, 2009 | Motorola Mobility RAZR V3
NOKIA 6610i display is ok but not showing any dail number on display but set is properly working. i have flased a mobile but problem remain. Thanks
i had a nokia 6610i mobile
the problem was i allways swithon the mobile but the mobile was swithoff before the mobile was fell down the mobile was swithes off itself allway not wroking ........pls resolve the problem
Nov 08, 2009 | Cell Phones
N70 DISPLAY IS BLANK/WHITE
Its a display IC fault.heres the screenshot..replace this two crystal IC for display.9323da0.jpg
Jul 21, 2009 | Nokia N70 Cellular Phone
Nokia N72 Display Problem
sir we need n72 display ic jumpers on the board
Jul 02, 2009 | Nokia N72 Cellular Phone
Nokia 6610 Logo
372 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
