Question about Sony CDP-C505 5-Disc CD Changer
Sony CDP-C505 door stuck open
The model has a 5 cd tray and is stuck in the open postion. Any assistance appreciated! The manual is not availabel anymore...of course.
  • budring Aug 17, 2008
    Many thanks for the help VOTIT. I am impressed with your knowledge base. Sometime in the next couple days, I will devote some time to this following your pointers and will get back to you again. Thanks again, Bud
  • 2,071 Answers
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 17, 2008
I have a sony cdp cx355 that seems to have a disc stuck and the door will not open to remove it. How should I proceed?
You have to remove the cabinet to expose the inner workings. Once inside, you should be able to see the stuck CD. Be careful to avoid damaging any parts of the player mechanism as you work the CD back into the carriage. You may find that once the CD is back in place normal operation resumes.
Sep 04, 2016 | Sony MegaStorage CDP-CX355 300-Disc CD...
Where can I get the "rubber band" that drives the
I think you are looking for tray loading belt as it is marked in below exploded view taken from service manual of CDP-C505
Belt part number is as follows:
492639901 ... Belt Square
It is available with PartStore.com for $5
Hope these info will help you, let me know if you need service manual copy.
Thanks.
Nov 27, 2010 | Sony CDP-C505 5-Disc CD Changer
Have had problems for a while not being able to open the drawer of my Sony CDP-C5F Compact Disc Player. It required my jiggling the cover a bit until it would open. Now it won't open at all. I realize this...
im probbaly guessing that the motor that drives the draw has given up and died what you could do is open it up and remove the motor from the draw but still have it plugged into the board turn on the cd changed and press the eject button and see if it spins without a load on it hopefully there is a model number on the motor it that you might be able to replace it with
May 10, 2010 | Sony CDP-C505 5-Disc CD Changer
My dics dor to its changer wont close
open it up
the tray has somthing stuck init
Mar 02, 2010 | Sony CDP-C445 5-Disc CD Changer
Need stereo remote for Sony 5cd changer FH-CX55
if you still have the owners manual look in the back of it for the remote model number. go to www.sony.com and look under support for parts and accessories. use the model number of the cd changer to find the accessory list.
Feb 04, 2010 | Sony CDP-C505 5-Disc CD Changer
In/out dial on bottom of Sony CDP-C305 ... what does it do?
It is Transit Key to protect optical lens mechanism from shocks while transportation unit. remove it before playing unit.
Aug 06, 2009 | Sony CDP-C305 5-Disc CD Changer
Sony model # CDP-CE415 Tray alignment off when closed
Your goin to need to re align the tray , your gonna need the service manual for this purpose. Go to this link :
http://www.nodevice.in/manual/Sony/page15.html ,hope this helps you, AJ
May 07, 2009 | Sony CDP-C265 CD Player
Sony 5 disk changer disk is stuck not able to open the tray
After some time it was showing some C 31 00 error. I searched on internet, opened the top cover, there is the CD changer and my cd was stuck in there, I pushed the CD from finger and there it goes... on press of eject it came out... thanks anyway...
Apr 02, 2009 | Sony CDP-CE375 5-Disc CD Changer
Tray will not stop opening and closing
You have to open the cabinet ..with the power off!! with tray open look at the laser it should be in the cd home position..move the laser toward away from the spindle motor or turntable.you should see a switch with a cover over it,it may be black or white or clear..the is your laser home switch..with your finger or small screw driver gentely push the switch towards you or bend it towards you.with the cover off.plug the unit up.Watch the laser as it moves away from you towards the cd spindle, it it stops and the tray moves in, and the cd mech chucks .you should see the laser turn on and see the objective lens move up and down..if it does not..and it continues with your original problem the you have to retime the tray and loading gear..try this first..
Nov 02, 2008 | Sony CDP-CE335 5-Disc CD Changer
CDP CX300 Disc player door remains open
Look on hifiengine.com for the service manual. I just got one for my Sony CDP-CX235 and there was definitely something about the door mechanism in it. The site is free to join too
May 03, 2008 | Audio Players & Recorders
Sony CDP-C505 5-Disc CD Changer Logo
488 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
