Question about Miele s558 Silver Moon Vacuum
I have a short in the retractable power cord. Is it an easy DIY fix?
  • jamesmei Sep 15, 2008
    I have a short in the power cord,sometimes it is on other times it is off.How can i take off the cover to have a look at the connections.
  • Anonymous Dec 31, 2008
    Seem to have a short on my Miele Silver moon. Have to mess with length on retractable cord to get power to turn on. Easy fix?
    Novelist:
  • 97 Answers
It is not generally necessary to replace the entire cord reel, although occasionally it is.
Here's the quick and easy DIY way to make your cord reel work again: you will need a #2 phillips head screwdriver, any flat head screwdriver, a pair of scissors, and a zip-tie.
First, remove the bag compartment lid by gently prying the hinge parts inward with the flathead screwdriver until you can lift it free. Remove bag and exhaust filter, and then remove the two screws holding the rear control panel on. Lift the front of the control panel upward until you hear a horrible unpleasant crunching noise. You didn't break it.
Lift that free, and remove all screws from the top of the main housing. (I believe there are 6 or so... but I can't remember off the top of my head.) The housing should then lift free.
You should now be able to see your cord reel. see if it wiggles back and forth along the central axle. If it does, you'll want to place the zip tie around the side of the axle which is away from the large round copper contacts which look almost like leaf springs. This will ensure that the contacts make electrical contact again. Cut off the excess zip-tie.
When putting the parts all back together, it is essentially a reverse of the disassembly, but be sure that you thread the cord through the hole in the back of the housing before you attempt to screw the housing down, or you will be very sad; both because you'll have to disassemble it again, and because you'll probably jack up your cord and have to replace the reel, which is what we're trying to avoid.
Test machine. If it works: party. If not, you will have to replace the cord reel.
For further clarification on the process, contact me.
Good luck,
-R
Posted on Mar 07, 2009
  • Joseph Bisognano
    Joseph Bisognano Aug 30, 2015
    I fixed it following his these directions! I used a plastic washer I found instead of tie, but followed the principles outlined. Eight screws, by the way. Even heard the unpleasant sound when I removed the control panel. I found a multimeter handy. On "ohms" and plugging in the control panel (but not connected to ac) I could see looking at the resistance across the plug that one way there wasn't a circuit and moving the reel the other way got a circuit, after I pressed the on off to get in the odd position. Thanks a bunch. Joe
Mine had the same prob. till it stopped working entirely
so i took mine apart, figured i had nothing to loose
the entire cord assembly needs to be replaced
check on the net to find the proper replacement part
i found one at miele s558 Silver Moon - moz-screenshot.jpgvacuums24x7.com
have not replaced it yet but thought it was worth the ~$130 try
still cheaper than a new miele or a repair bill
keeping my fingers crossed
good luck
Posted on Jan 08, 2009
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
How do I fix the retractable cord on a Dyson DC19 vaccum cleaner
Great Youtube video
https://www.youtube.com/watch?v=4p0N2XwiKaw
Aug 22, 2014 | Dyson Vacuums
360 manual
With all that's involved in replacing the cord and potential cord reel damage, it's more cost effective to just have the entire cord reel, complete with new cord, replaced. Less time consuming thus less costly to you. Hope it helps!
May 26, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Repair retractable cord
Depending on which model of Electrolux you have and how far out you have pulled out the cord (most of the Electrolux canisters have a yellow tape around the machine end of the cord to alert you not to pull it out any further), you might have to take it apart to fix it. However, the first thing that I would try would be to stand it on the end (the hose end at the top), and pull short jerks on the cord to see if it will correct itself and retract. If that does not fix it, I would stick a screwdriver in the hole where the cord comes out of the machine and attempt to wind the cord reel back up which will slowly wind the cord back up on the cordwinder. This usually cause the cord to wind back up. If that does not work, then the only option is to take the machine apart to fix it.
Dec 11, 2013 | Electrolux Vacuums
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Feb 12, 2011 | Vacuums
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Sebo K 3 Vacuum
I had a problem with my K1 Komfort model which sounds similar to this. I initially thought the cord was too short but the machine wouldn't give out anymore and retracting was difficult. A Sebo engineer/helpline told me to pull roughly on the cord, of which I did and was rewarded with 2 metres more than what I thought I didnt have! So, perhaps if your machine isn't retracting properly, give the cord a rough pull with gloves on, or a strong grip - the cables on the K series are notorious for stopping up. Afterwards wipe the entire cord down with furniture polish; it will retract much more quickly.
Feb 21, 2007 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Miele s558 Silver Moon Vacuum Logo
1,544 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
