Bose Acoustimass 3 IV System Logo
Posted on May 31, 2011
Where is a balance control function on the onkyo cr 325 with bose acustics?
1 Related Answer
Anonymous
  • 59 Answers
  • Posted on Dec 18, 2008
SOURCE: lifestyle 5 model 5 acustic systems
http://products.bose.com/pdf/customer_service/owners/og_ls_vclass.pdf
Good Luck!
Does my onkyo cr 325 reciever have bluetooth capabilities?
Nope. https://www.manualslib.com/manual/115270/Onkyo-Cr-325.html?page=7#manual
4answers
Bose Cinemateonnect
Hi lechap,
With the indulgence of IB4G2008 as per his last post Feb 13.....
If I figure your concerns right, they are:
1. You have an iPod on an Onkyo IPod dock that you want to connect to an Onkyo receiver TX-302;
2. You have an Onkyo receiver TX-302 that you want to power a set of Bose Cinemate speakers;
3. the connectors on some do not fit or are not the same;
4. you want to know what goes to where.
If I may suggest:
a. connect the L/R Audio Out of the Onkyo IPod dock to the L/R Audio IN of VIDEO 1 using a pair of RCA to RCA cable. Connect the S Video Out of the Onkyo IPod dock to the Video IN of VIDEO 1 using an S Video to RCA Video cable. Thereafter if you want to watch a movie or play music from your iPod, you need to choose Video 1 in the Onkyo receiver TX-302. You can of course choose any other VIDEO 1~3;572fcdc.jpg34ab5d3.jpg
b. all other source/devices may be connected similarly using the same scheme on any of the free VIDEO / AUDIO inputs
c. of course the MONITOR OUT goes to your TV or projector.
With respect to the Bose Cinemate, it would not be technically correct to connect the Bose Cinemate speakers straight to the speaker out of the Onkyo receiver TX-302. You need to install another set of speakers to the speaker outs of the Onkyo receiver. The Bose Cinamate system's TV AUDIO could be connected to the TAPE OUT (or the AUDIO L/R OUT of VIDEO 1)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
1helpful
Help. I purchased a Onkyo Model TX 8555. I then purchase a set of Bose 901 Series V speakers that come with a Bose 901 equalizer. I cannot hook them up. Does anybody know how to do this.
The TX 8555 can drive the speakers directly but if you want to use the equalizer then you need to add an amplifier to the system so that you can feed the pre-amp connections from the TX8555 through the equalizer and then into the amplifier to drive the speakers. This is because the TX 8555 doesn't have a loop back function for monitoring recordings.
1helpful
My 321 remote does not work
Yes Contact Bose They will Help you. I also have a Bose,but if the receiver is Built by ONKYO and you have had this for more than a year you might have a problem. They(onkyo)require a receipt. The Techs are fine but the lady you will end up talking to is well just say not so nice. Good Luck
Onkyo CR-325
According to the manual, the sleep timer can be set to shut the unit off after a specific time. The other timers can only be used to trigger the amp to play or recored at specific times, and only if the recieiver is left in standby, otherwise the timers are ignored. There should be no reason the sleep timer does not work if you are following the procedure outlined in the manual (http://safemanuals.com/user-guide-instructions-owner-manual/ONKYO/CR-325-_E)
Sounds like the transformer or something went in the other amp. Not related to the timer issue. Both amps having the smae timer issue suggests that it is a programming issue (follow the procedure in the manual step by step), if you still cant get it to work, get it covered under warranty while you can.\
Hope this Helps
Jer
3helpful
Bose 901 speaker with eq
You want them to be your Main Front speakers, right? The news is not good.
There will be some limitations because you can't extract 'processed' L-R from this receiver. The following will give you good stereo and Front L-R from the 901's but it won't allow central volume control or send them any of the DSP effects you may select. Sorry. If it had a Front L-R Pre-Out you'd be good to go for all functions and listening modes.
You'll need a separate stereo amplifier WITH ITS OWN VOLUME CONTROL for the 901's to accommodate the need for the Active EQ. Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
With this receiver we have to cheat to get the Front L-R signal out to the 901's (but it's unprocessed and at a steady volume level)...
For connection I would run a pair of RCA cables from the VCR/DVR Audio Out L-R OUT jacks (*) to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp.
* You'll lose the ability to use these jacks for anything else, but few of us use them anyway. DO NOT select this function for monitoring or you lose all audio in the Onkyo.
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
2answers
Do all speakers need to have the same impedance? (Protect mode)
Amplifiers sometimes like to have "balanced loads" on them, and this may be the case with your unit, meaning yes, all the impedances should match.
Judging by the impedance numbers you provided, you should be all set. You really want to avoid having something like 2 ohms on the left side and 8 ohms on the right side - grossly imbalanced. I don't see any problems with what you're going to run.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
