Question about Panasonic SC-PT960 Theater System with Wireless Speakers
About the whole system and how it work. help!!
Ok. I trying to bid for an item on Ebay and it says that the DVD player says "Changer Error". So for my best knowledge, it just won't play DVD, right? I don't really need regular since I have already upgraded everything to Blue-Ray with my PS3. So my main question is that I know that the Panasonic sc-pt960 comes with wireless capability and does the wireless still works without the Panasonic DVD box..?! I mean, what does changer error means anyways?! help!!!!! please!!!
Mine has the same issue. you can use the other functions, but it is rather annoying having to wait for the system to figure out it is broken. You could just remove the DVD player so it doesn't test it every time you turn the power on. I opened mine up and figured out it was just a plastic piece that came lose and jammed the DVD rack. Im going to contact Panasonic to figure out how the piece goes back in.
Posted on Nov 07, 2008
Jon95 did you ever figure out how the piece goes back in? I have the same error message and am trying to figure out what the problem is. The tray loads but something is jamming it causing the error. Where was your loose part?
Posted on Aug 23, 2010
  • 3 Answers
Just take out the metal cover, remove the DVD player (its is attached to mother board by three tiny connectors) and close it again. Be careful not to remove the three connectors that attach the front panel with the motherboard. If you do, be patient to put them back since you will have lousy connections when turning the unit on. You may loose the front LEDs if the third connector is to deep or too loose. You are loosing the DVD player but you will be able to put the unit in D-IN mode and use the optical connector. Nobody use that crappy DVD player anyway.
Posted on Apr 26, 2011
  • Alex Fayer Oct 24, 2011
    I removed the DVD tray and it is stuck on am/fm mode. I can change between the two (am or fm) but can't get any other input to select. I have tried both the selector button on the player and the select button on the remote, but neither do anything. I have tried unplugging it for an hour to reset it and it still says changer error when I try to do some things and just ignores other commands. What can I do?
  • Dan Broun Jan 17, 2012
    @alex fayer any luck? We have had the exact same thing happen. Any ideas?
I had the same problem as well. I just decided that since it was WAY past warranty time, and the model has been discontinued, I might as well take it apart. I found a little black arm like piece of plastic floating around inside the trays. I can't figure out where it goes exactly but I just removed the dvd trays and can at least use my surround sound!!! That's what mattered the most to me, I can use my PS3 for dvd/blue ray.
Posted on Sep 01, 2010
  • reggaebadboy Feb 01, 2011
    I found that same black plastic piece and found it where it goes but I still have the same changer error problem. I really dont care for the DVD player because I also have a ps3 and my main concern is getting my AUX function to work so that I can still use my surround sounds for my tv. How did you take out the dvd trays? Did this allow you to switch through functions normally again? Please help!
I have all the speakers for the protron pds-2315 home theater system. I just need the dvd player.. Where can I find/buy just the dvd player for this system?
You could check the auction sites. I see the whole set on eBay right now for cheap. When bidding, strike at the last 10 seconds to prevent having to bid against yourself.
Jul 05, 2011 | Protron PDS-2315 Theater System
My 5 disc dvd player wont read dvd's any longer. It doesn't even say they are in the changer. I tried a dvd cleaner and that didn't work, because it didn't stop on that disc. I tried opening the top to be...
The laser lens circuit itself is faulty if cleaning doesn't work. The capacitors and other components can wear out and overheat and burn out through time. You can get another from many suppliers including ebay. and
http://www.toocle.com
www.tradekey.com
or try to adjust the lens. See how:
www.ehow.com › ... › DVD Players & RecordersDVD Players
Dec 12, 2009 | Samsung HT-HDP40 System
SAMSUNG HOME THEATRE HT-Z310 will not play dvd's everything else works ok just comes up disk error on all dvds
if its less than 1 year old get it fixed by samsung. if older, buy a new dvd drive http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390140887510
Nov 22, 2009 | Samsung HT-Z310T Theater System
LG HDD/DVD player - navigational error message
HI,
DVD shrink can't handle the copy protection on the disk you're trying to backup, use DVDFab decrypter first instead.
Get it here:
http://www.dvdidle.com/download/DVDFabDecrypter29.exe
Use DVDFab to rip the files to your HDD, it will create a VIDEO_TSfolder and put all the video files in it. DVDFab is a whole movieripper only, so you're getting everything on the disk ripped to you'reHDD, once DVDFab is done, run DVD shrink. Use DVD shrink to open thefiles created by DVDFab (use the open files tab and browse to theVIDEO_TS folder created by DVDFab and choose it), at this point shrinkwill import the files, use shrink as you normally would to create yourbackup.
thank you for using fixya,rate my answer,
vijay
Oct 04, 2009 | LG LXD5230 System
2005 350Z 6 disc changer / error message
Use a Laser Lens Cleaner. Run it thru the player a couple times. Use one that has fluid with it, you can find them at any electronics retailer for 15-20. If it still has the same problem, the only thing to do is send it for repair, they will replace the transport. Average cost of 125-175 on a changer. Hope this helps
Jul 01, 2009 | Bose 3·2·1 II System
LG home 5 disc dvd changer
try to clean the dvd player it could be the lens that is having a hardtime reading the disk and it causing the noise
Jul 21, 2008 | LG LXD5230 System
Dvd tray do not open
Someone on this site suggested a fix for a different player.  Open up the unit to get to the dvd changer.  If the disk are not aligned, then push them so they are even.  It may take a while to see where they are but it worked for me.
Jan 14, 2008 | NexxTech ESDVD100 System
Panasonic SA-HT692
that just happened to me last night. do you know if there is a disc inside the player? it's possible it is stuck and preventing the tray from opening.
Jan 04, 2008 | Panasonic Home Theater System System
The dvd tray .
you can not you need to buy a whole new dvd player or get one that is non working from eBay and use that tray to replace yours
Aug 22, 2007 | RCA RTD255 System
DVD stuck in changer
pls take the system to authorised showroom to get it reapired as the tracking system is not on its tracks ,pls donot try it at home as u will ending up damaging ur system
Jun 04, 2006 | JVC TH-M505 System
Panasonic SC-PT960 Theater System with Wireless Speakers Logo
603 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
