Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 52W23 I tried to turn on the TV ( RCA 52W23 ) and all that happened was the power light flashed over and over again. Any idea what may be wrong?
  • Anonymous Aug 19, 2008
    Power light keeps resetting (set does not come on)
    Genius:
  • 2,920 Answers
Bad power supply its pretty common
Posted on Aug 18, 2008
My RCA 52W23 52-inch HDTV will not turn on anymore. I can hold the power button down and the green light will blink once, but nothing. If I press it again, it blinks several times, but nothing. Before...
The deflection board will ned to be replaced. You can get replacement deflection boards from www.tvrepairworld.com they will help assist that you get the correct board for your model.
Jun 25, 2010 | RCA D52W23 52" HDTV CRT TV
Good morning, My tv is only 3 1/2 years old. It just stop working, I changed the batteries in the remote and still won t work, I will try to turn it on, it comes on for about 2 seconds then goes off...
Hi, there must be something wrong in the power supply circuit, usually because of bad or off value components, if the TV actually gets a picture and cutts off, the power supply could be the circuit to suspect, if the tv does not give a picture, it only does the click and the power light turns on but nothing else happens, there could be something else wrong besides the power supply circuit.
Mar 20, 2010 | RCA 20F610TD TruFlat TV/DVD
I have an RCA D40W135D with ATC221. Will not come
Sounds like the HV splitter, Very common problem with that chassis
Nov 22, 2009 | RCA D52W19 52" Rear Projection Television
RCA Proj TV (model D52W14) Power light flashes 3 times
Replace CP150, CP120 and CP114. You can get the repair kit for your RCA at the following link. www.tvrepairworld.com the kit contains the capacitors and the CD with detailed instructions.
Sep 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA L42WD250 42 in. will not turn on
Try unplugging it for 30 mins. If it still has the problem, it may have when into protection mode.
When this happens, a part in the TV when bad. The protection mode keeps the TV from staying on to prevent further damage.
At this point, I would use the warranty on the TV. Being that it's only 6 months old.
Feb 08, 2009 | RCA L42WD250 42 in. LCD HDTV
35" RCA 35" Entertainment Series - PIP
ok is the set completlely dead. DOEs the Led on the front flash. if it does not flash this is an indication of a primary power interuption. POSSIbley main fuse. Now generally the main fuse does not blow unless there something else wrong. some other component shorted. Now if the light flashes then this is an indication that the main fuse is still good and that the processor is getting power and that it has detected a condition that requires it to shut down. ussaly a high voltage issue
Dec 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca lcdx3022
This happens when the tv cpu detects an internal problem, for example an overvoltage, a short, or a faulty component.
The tv goes in protected mode, and activates a safety switch that turn immediately the tv off, that is what is happening to your tv.
Try unplugging the tv for one hour or so, this will drain power from the unit, and reset the TV chips, in case the TV is "wrong" about the problem.
If it does not works it means that the tv has an internal fault, in this case you may need to call a technician if you want to fix it.
If you need to call a repairman you can use the phone number listed on the owner manual.
Sep 14, 2008 | Televison & Video
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
F32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Nov 30, 2006 | RCA F32650 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
