Question about Onkyo Audio Players & Recorders
No sound I have connected the speakers but no sound, the cassette tape is moving as if there is sound but the speakers are not working. I do no that the speakers are good. What could be the problem
  • 2,071 Answers
Use your speaker to another unit if it working, if not then the problem is your speaker,other checking technic use a multitester set it to X1 check the lead connection of the speaker if has a resistance 4ohms or 8.
hope this may help;
Posted on Aug 17, 2008
Will it record on most cassette types
The difference between cassette types is the length of the tape and the quality of the tape. Your recorder will work on all types of cassettes.
Dec 17, 2015 | Panasonic RX-D55GC-K Boombox - High Power...
How do I re connect my equipment after a move?
Your input's that you need to use are labeled on the rear of the chassis. Make ALL of your connections with the power cord unplugged.
The connection types for each component that you'd like to use are also labeled. For the CD player you may see such connections as coax, optical or L& need to only connect one type. What's available depends on your receiver. For a cassette tape player however there will be only L&R, connect from the L&R outputs of the player into the L&R input on the receiver.
For your speakers, you have a couple of options depending on what you have connected to your speaker cables but the most important thing is getting the polarity connected properly. Not all speaker cables are color coded for polarity but instead have a marking on the insulating sheath along the entirety of it's length or may simply have one silver wire and one copper wire. You only need to make sure that the polarity of the connecting terminals between the receiver and speaker match; having the cables marked is only to make that connection easier...just connect one wire at a time, and make sure that your speaker placement position also matches the terminal you're connecting to.
Dec 28, 2014 | Audio Players & Recorders
Curtis mathes what parts am i missing i have no sound i have the cassette deck an am fm recever
Perhaps you need an amplifier and some speakers to? And don't forget the cables to connect everything. Then connect the receiver to an antenna and put a cassette with music in the cassette deck before pressing the play button.
Nov 19, 2014 | Audio Players & Recorders
I have a Harman Kardon CDR 30 that I use to burn my analog Vinyl and cassettes to CD. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
do you remember how your connection was before the RR tape deck? if so connect it back that same exact (when every thing was recording / playing) way as before....(you also need to purchase 4 gold tip "y" connector jacks (2 RCA female to 1 RCA male)) ... in / out jacks you just plug the cassette deck will be shared with the RR tape deck...just note you will not be able to record from cassette to RR tape or vice versa...but you will be record from all other sources...
feel free to rate the help
Mar 27, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Reorded tapes only play out one speaker
check your cables to the units channel that doesn't work, for breaks. Does the cassette player play back a pre-recorded tape okay? if it doesn't there might be a internal fault.
Check the wires to the tape head to see if one is off.
Jun 06, 2009 | Kenwood CT-201 Cassette Player Single Dual...
Cassette issues
Could the tape be a Mono recording? Have you tried to clean the head on the tape player? This could fix it if the head is dirty. Do you use the tape player very often? It could have a dust build-up. Hope this helps...
Sep 01, 2008 | Sanyo FXCD-550 CD / Cassette Player
1995 Saab 900S Left speaker doesn't work when using tape player
sounds like the cassette adapter has a bad channel, or didn't fully seat into place. Try removing and re inserting, to play the other side of the adapter if the wires will allow it. Then auto reverse the cassette deck to allow a different portion of the cassette head to be used for the signal. Those cassette adapters are poor quality, and put alot of time on the mech.
Jul 12, 2008 | 1996 Saab 900
Vol problem
Here is the entire troubleshooting section from the manual.
Your problem is presumed to be a shorted speaker wire. I assume you're not getting the failure ONLY at extremely high volume levels.
Care and maintenance
Occasional care and maintenance of the unit and the software
are needed to optimize the performance of your unit.
To clean the cabinet
Use a soft and dry cloth. If the unit surfaces are extremely
dirty, use a soft cloth lightly moistened with mild detergent
solution. Do not use strong solvents such as alcohol, benzine
or thinner.
To clean the tape heads
Dirty tape heads cause sound deterioration. After every 10
hours of use, clean the tape heads with a head cleaning
cassette. Refer to the instructions of the cleaning cassette.
To demagnetize the tape heads
Use a demagnetizing cassette after every 20 to 30 hours of
use. Refer to the instructions of the demagnetizing cassette.
Care of CDs
When a CD becomes dirty, wipe it from the center out with a
cleaning cloth. After playing a CD, store it in its case. Do
not keep it in hot or humid places.
Care of tapes
Store tapes in their cases after use. Do not leave tapes near
magnets, motors, television sets, or any source of
magnetism. Do not expose tapes to direct sunlight, or leave
them in a car parked in direct sunlight.
If your unit fails to perform properly, check the following guide
and the relevant sections of the Operating Instructions.
There is no sound.
•Are the speakers and AC power cord connected properly?
The unit shut off suddenly.
•Possibly a short circuit in the speaker terminals.
Disconnect the AC power cord from the AC power outlet
and re-connect the speaker cords correctly.
The unit blacks out when the unit is turned off.
•Is ECO mode set to on?
Erroneous display.
•Reset the unit.
Poor radio reception.
•Check antenna connection. Adjust the antenna to find the
best reception.
•Move unit and antenna away from other electric appliances
and cords.
The tape does not run.
•Is the deck in pause?
Poor tape sound.
•Check for dirty heads. Clean them if needed.
•Use type I (normal) tapes.
Cannot record.
•Is the erasure prevention tab of the tape broken off? If so,
cover the detection slot with adhesive tape.
The CD player works poorly.
•Is the disc correctly loaded?
•Is the disc dirty?
•Is the lens affected by condensation? If so, wait
approximately one hour and try again.
Resetting the unit
If an unusual condition occurs in the display window or the
cassette deck, reset the unit as follows:
1 Press POWER to turn off the power.
If the power cannot be turned off, disconnect the AC power
cord, then plug it in again.
2 Hold down s and press POWER.
Everything stored in memory after purchase is cleared.
May 03, 2008 | Aiwa NSX-TR77 CD Shelf System
A Real Speaker Jacks..
There should be a switch position on your system that you move to allow the sound to come out to standard speaker configuration or to multiple speaker configuration.
This switch may be on the front or rear panel.
Please have alook to see if its there....
Its possible the these Real speaker jacks are not wired to anything inside the amp system, and are there for use on a different model where the selector switch is supplied.
B Cassett Deck..
The clicking is caused by the motor trying to drive the wheels that turn the cassett tape.
It sounds like something is jamming the internal drive mechanism.
The drive belt may have come off or is stretched and is slipping.
Have a good look inside the front slot and you may see one of these items described above happening..
It may have to be serviced at a workshop.
Cheers From YUBEUT.
Dec 04, 2007 | Denon D-1000 Shelf System
74 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
