Question about Saeco Magic De Luxe Espresso Machine
Saeco magic comfort is leaking water from under the water tank
  • 515 Answers
I think you have to replace the gasket in the waterinlet.
Spare part number: 145842900
/Mirran
Posted on Aug 17, 2008
2 Suggested Answers
  • 81 Answers
SOURCE: Tank leaking on saeco magic comfort coffee machine
Hi,..There is a seal on the machine where the water tank sits, you have to pull out the retaining plastic ring and replaced the seal.
Posted on Jun 17, 2010
My saeco magic plus leaks water when the tank is full
You should check the water tank gasket which is located directly under the water tank.. It is not part of the tank. It's on the machine side.
See the video on our page.
http://www.cerinicoffee.com/saeco-water-tank-gasket.html
Aug 28, 2013 | Miele CVA615 Espresso Machine
Tank leaking on saeco magic comfort coffee machine already replaced tank and still leaking Laura
Jun 16, 2010 | Saeco Magic Comfort Plus Espresso Machine
How do you descale a Saeco Magic Comfort Plus coffee machine? do you buy some fluid from somewhere and pump it through or what?
Hi
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Jun 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
  • The first thing you need to do is go to your menu. Scroll down to water hardness and push the enter button. Use your up arrow and move the number to 4 if it is not already there. Push the enter button. Once it is on 4, then scroll up to descale machine and push enter. Have your solution (NOT VINEGAR) Citric Acid dissolved in solution and put into water tank. Now open the knob for steam and let the machine do its thing. When it is all done it will say "Finished descaling". Rinse out the water tank and put in fresh water. Close the knob and then reopen it again. When it finished rinsing scroll down to "Reset Descale" Push enter and choose "Yes" with the arrow and push enter. This will bring up a message when it needs to be descaled again. You can also see how many coffee’s you have made. It’s just above the Descale Machine in your menu. Descale more often than Not Enough will keep your machine working well into the future.
May 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
On my SAECO Comfort + machine, the ''Fill Water tank'' message does not go off even aftre the tank is filled.
make sure the magnet inside the water tank can move freely or float if it is then thr sensor inside is faulty
Nov 28, 2009 | Saeco Magic Comfort Plus Espresso Machine
My saeco magic comfort plus is spilling water out through the bottom of the machine. there is water in the little hole next to the brewing mechanism.
water from under the machine is almost always the boiler.
In some rare cases it is the flow meter.
Needs to be sent in for repair.
Aug 07, 2009 | Saeco Magic Comfort Plus Espresso Machine
Says "Fill water tank" and the tank is full
did you open the side valve to ventilate the air in the system in our water tank do you have a little magnet its in the water tank maybe it stuck downshake the water tank to move the magnet up pierre
Jan 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
For saeco magic comfort plus, I can't purge it! the purge indication is always on even if i use the water, steem etc. what can i do ?
in the kit of the machine they give a little pump if you dont have it use a turkey blaster the toll when you cook a turkey to put juice on it use that remove the water tank fill the blaster with water open side valve put pressure on the blaster put it in the hole where the water tank goes and apply as mush pressure as you can repeat it should vent itself if sign goes off refill water tank that it pierre
Dec 21, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
205 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
