My Hatachi TV (60sdx88ba) has double images. - Televison & Video
    Problem Solver:
  • 11 Answers
I have this same tv and fixed it repalcing the two stk ics
Posted on Dec 10, 2008
I have a Hitachi 60sdx88ba UltraVision Digital Projection TV @ the top of the screen a yellow swoosh 6 inches wide with a blue line 8 inches under it. On the right bottam a 3 appears. Double image on the...
You have a defect in the convergence circuit. Both chips will need replaced and possibly a resistor or two. Chip part numbers are STK392-110. Typical repair runs around $350
Bill W
integrityhomeworx.com
Mar 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
TV Hatachi 50UX22BA turns off after about ten to 30 seconds after
No, Replace both of your STK ICs STK392-110s use 150s Mats has them 1-800-628-1118
May 11, 2010 | Televison & Video
I have a 60sdx88ba and will not power on
First I would check to see if you may have shorted the STK ICs pins when you soldered them in. There may be more than one short, so check them carefully.
Next I would check to see if that circuit uses ant fuses or pico fuses on the supply lines to those ICs.
Good luck.
Dec 01, 2009 | Hitachi Televison & Video
Remove base off my 37 inch hatachi tv we hung on the wall
there are 4-6 screws or bolts on back near middle bottom of tv usely marked with arrow or S
Nov 28, 2009 | Hitachi 37 in. LCD TV
Hitachi 60SDX88BA
no picture condition could be caused by a problem in the horizontal deflection circuit or a power supply failure. A horizontal deflection problem often are followed by open fuses due to shorted components such as a h.o. transistor ofcourse there are a lot more componentd that constitute this circuit. Another no picture condition could be caused by defective convergence power amps. these amps usually give an clear indicator when they are about to quit(color curved or missaligned, double color images etc.) this is a common problem with projection tvs and that is where I would tell the tv tech to start looking.
Sep 19, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Double images
hi, convergence circuit has failed, will need a tech or someone very proficient at solder work to replace your convergence ic`s & possible support parts, if your that person re-post and i`ll try to help ya, video-tek
Jun 06, 2009 | Hitachi 57F500 57" Rear Projection...
I need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
Jul 24, 2008 | One For All URC-3021 Remote Control
Hatachi 53uwx10a picture out of focas /words are also double and a yellow line about 10 inches thick sloops down from the top along the top of the tv
i replaced the ic's on the video convergence board ,wasnt hard . they were STK392-110 amplifiers , they had no heat sink paste on them ! everything else checked out fine
Jun 29, 2008 | Televison & Video
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Double image
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Mitsubishi VS-45609 TV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
