Question about Frigidaire PLEF398AC Electric Kitchen Range
The LCD Display/Clock that controls the
Oven went shut off just yesterday, does not appear to be an issue with the outlet. I remember walking by and looking at it to check the time and the display was dead as if the oven had been powered off, oddly enough the eyelids work just fine just the display and of course the stove do not operate (have no power what so ever).
  • 639 Answers
Hi lwb,
Happy to help you!
But I see that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 24, 2008
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
Electrical panel does not work
Hey John, this is JK. I understand that the display on your range is not working. You may have a faulty Electronic Oven Control (EOC). Please confirm there is power to the appliance. If there is no power verify that the power cord is properly attached to the unit, plugged into a dedicated outlet correctly, and that the circuit breaker/fuse is not tripped or blown. Also verify the power at the plug is correct. Is the time of day displayed when the clock button is pressed? Are you able to turn the clock OFF or ON? When the display is turned OFF the time of day will re-appear for a few seconds any time the pad is touched. To toggle the display ON or OFF, press and hold the CLOCK button until the control beeps once (about 15 seconds). If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect. Hope this helps!
Apr 07, 2014 | Frigidaire FPGS3085KF Professional 30"...
I Have the whirlpool Oven RBD306PDQ8 - The power went out in our neighborhood, when it came back on the clock display will not appear. We can set the clock, it stays on the panel for about 10-20 seconds...
When the power came back on, it sent a power surge to the ERC (clock assembly). Try turning the oven breaker off for 10-15 minutes, this is to reset the ERC. If the display still doesn't work, you will need to replace the ERC-Electronic Range Control.
Oct 04, 2009 | Ovens
F2 appeared on the screen during self-cleaning
F2-During BAKE
Control senses oven temperature above 615F-630F
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
F2-During CLEAN
Control senses oven temperature above 915F-930F
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Apr 16, 2009 | GE Profile Spectra JBP95 Electric Kitchen...
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Oven controller not functioning
9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
  • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
    Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Nov 04, 2007 | Frigidaire FEF336BC Electric Kitchen Range
No display - oven/timer/clock inop.
Most likely control / clock has gone bad and needs replacing
Nov 11, 2017 | Frigidaire GLEF396 Electric Kitchen Range
Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
Apr 08, 2007 | Frigidaire FGB24T3A Gas Single Oven
Frigidaire PLEF398AC Electric Kitchen Range Logo
110 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
