FixYa.com
Tags:
Olicom SmartSwitch 6000
Segmentation
By pandamama - usenet poster
The company I work for has around 130 machines on a single ring, token-ring
network.
Once everyone is converted over to 16MB we're probably going to be looking
at additional ways to increase bandwidth, the MAU's were using are IBM
8228's & Olicom OC-3626's.
I'm thinking about using a switch to segment the network into multiple
rings, my question though is how exactly do you do this if the switch and
the MAU's are connected through their RI/RO ports ( I know this sounds like
a stupid question but my only experience is with single ring TR networks.)
Also are there any particular switches that seem to perform better, or that
are more compatible with the MAU's we're currently using?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 07, 2005
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
See below please.
On Mon, 24 May 1999 11:35:20 -0500, "Rob Thompson" <a @aaa.com>
wrote:
This is correct.
This is not correct.  (But you can do this, if you are feeling
terribly masochistic)
I think I understand your confusion.  I'll try and explain and
hopefully not confuse you any further.
Each port on the switch acts as a lobe connection to the MAU.  Using
what is called a Concentrator Relay Function (CRF) it binds groups of
switch ports together as one logical ring.  This could be *crudely*
interpreted as something of a CAU/LAM arrangement, with the switch
being the brains of the bunch, and all the dumb MAUs being the LAMs.
Make sense?  I hope so, cause I probably pissed off a bazillion TR
purists out there with that description (flame suit on).  If anyone
else can come up with a better description, please have at it.
Chad
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
The only part I'm confused on is the RI/RO structure, is it:
A:    A line from Port #1 ( or whichever port ) on the switch, to Port #1
 or whichever port ) on MAU#1, and simply wrapping RI/RO cables on however
many MAU's there are on that particular ring, or:
B:   A line from Port #1 ( or whichever port ) on the switch, to RI on
MAU#1, and a line from RO on the final MAU to Port #2 ( or whichever port )
on the switch to form the ring.
The main reason for my confusion is i guess, that I thought communication
between the switch and the MAU(s) requires a RI/RO
structure to "bind" the ring rather than simply running a single line from
Port "1" on the switch to Port "1" on the MAU.
Solution #3
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
The ports of the switch plug into the MAU's just like any other node
on the ring. The RI/RO are used for connecting  multiple MAU's into a
ring.
Solution #4
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
First try to figure out how much bandwidth you're really going to need. It's
extremely difficult to tax a 16Mb token ring LAN, even with 130 machines. We
hardly ever see bandwidth limitation problems on local token rings with over
200 users. We have approximately 1300 individual token rings with anywhere
between 8 to 200 or so users per ring. The bandwidth limitations generally
form when a ring is bridged to another ring, and then only when it's a
remote bridge, local bridges can approach ring speed and are largely viewed
to be transparent from a bandwidth perspective. I would be very surprised to
hear you have maxed out on a 16 Mb ring with 130 users. You're likely to run
into other problems before bandwidth really becomes your problem.
Congestion, faulty wiring, etc. etc. are likely to be your problems before
bandwidth.
When you decide to move to a multiple ring configuration, whether through a
bridge or through a switch, you break down the single ring into multiple
segments and provide for some type of connectivity. Bridges connect two
segments together. Routers do the same thing but with more intelligence.
Each segment has one token to service it's clients with. Switches provide
for a token per port. We are moving to high speed switches only in our large
buildings with over 1000 users where there is already a local 16 Mb backbone
in place and 16 Mb locally bridged user rings. The switch does provide for
more robust, speedier service, but you may be using an elephant gun to kill
a mouse.
If you're even able to run at 4 Mb, the jump to 16 will be major, in terms
of capacity, and if you're not really taxing the 4, you won't even notice an
increase in performance. You have to be hitting the wall at 4 regularly to
be able to enjoy the additional bandwidth of a 16 and notice it.
Solution #5
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
I'd recommend the Olicom OC-8600 or OC-8601 series.  Rock solid
reliable, easy to configure (if you have to), fast, and HSTR capable.
We replaced a bunch of IBM gear with these, and couldn't be happier.
Reasonably priced too.
As far as connection goes, the OC-8600 is a 20 port switch.  Connect
one 8228 to each port on the OC-8600, and you are good to go.
Everything else is pretty much automatic, but you might need to set
the ring speed on the ports (easy to do with the supplied utility).
Just disconnect or wrap the RI/RO ports on each box.  Voila!  A bunch
of little rings!
If you have ports left over on the switch, connect your servers to
them at full duplex (if your NICs support that).
It's really easier than it sounds.  If you are still confused, drop a
line.
Chad
On Sun, 23 May 1999 20:26:57 -0500, "Rob Thompson" <a @aaa.com>
Can you Help with these Networking Hubs and Switches problems?
my renter messed up the...
Got a call from a tenant that... Answer This...
messed up shape
i just messed up with its... Answer This...
to speed up internet
how can i increase internet... Answer This...
I'm not getting free download ...
sir i'm abdul bari i need cisco... Answer This...
my euro box has gone off
dvb,xc box this is the make of... Answer This...
Repair Service
Find Networking Hub and. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
