Will it support it ?
Will my socket 939 jetway 939gt4-sli-g support a
AMD Opteron X2 180 2.40GHz
  • lemonvodka56 Aug 17, 2008
    Free Image Hosting at www.ImageShack.us
    QuickPost Quickpost this image to Myspace, Digg, Facebook, and others!
    opps dont work like that
  • 56 Answers
Go to the manufacturer website of the motherboard you have. From the website you can look up the specs of the specific motherboard. It will list which CPUs that motherboard supports on the specs page.
Posted on Aug 19, 2008
I was wondering if my 939GT4SLI-G can run PCI Express 2.1 x16. Example of a video card would be, MSI R6950 Twin Frozr II OC Radeon HD. Thanks, Rob
This is your board:
http://www.dealtime.com/Jetway-JetWay-939GT4-SLI-G-Socket-939-NVIDIA-nForce4-SLI-ATX-AMD-Motherboard-Retail-939GT4-SLI-G-BRAND-NE/info?sb=1&tab=specs
This is the card you want:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127575&nm_mc=OTC-RSS&cm_mmc=OTC-RSS-_-Desktop%20Graphics%20%2f%20Video%20Cards-_-MSI-_-N82E16814127575
Some say that the card will work but with limited capacity. I don't see the power requirements for the card but, I would guess a minimum of 350w or greater. Your board definatley was not designed for this card. It's alot of money for a card that may not work at all with your system.
This is MSI's link:
http://us.msi.com/index.php?func=prodvgaspec&maincat_no=130&cat2_no=&cat3_no=&prod_no=2093#menu
There is a "contact us" link at the bottom of the page where you can try to ask them but, in my opinion, for the money, I don't recommend the card without upgrading your system.
Dave
Jul 01, 2011 | Jetway 939GT4-SLI-G Motherboard
How many graphics cards can you run on this motherboard ? also whats the maximum ram you can install on it ?
You may install 2 x PCI-Express X 16 slot, supports two PCI-Express interface Graphics cards with SLI mode and 4x1Gb Dual channel DDR400/ 333/ 266 -184pin RAMs onto your AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI Chipset 2000MT/s FSB Dual Channel DDR400 Socket 939 ATX motherboard.
Check out your motherboard's specifications through this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 09, 2011 | AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI...
Jetway motherboard 939 GT4-SLI-G will only accept 3.5 gig RAM and not 4 gig RAM as per specifications. It does not run on gaming applications when 4 gig inserted (4 x 1 gig). Any solution?
If you are running a 32 bit version of windows it will only see up to 3.5gig of ram in your system no matter how much ram you put in there.
This is down to 32 bit windows only being able to address a maximum of 3.5 gig of ram.
Windows 64bit can address a far larger amount of ram and is why you will see all windows computers running 4gig or more of ram having Windows 64bit installed.
As you have said your computer is running Windows 7 32bit the only way you will get your computer to see the whole 4gig of ram you have installed is to upgrade to Windows 7 64bit.
Hope this answers your question and helps you out.
Jan 18, 2011 | Jetway 939GT4-SLI-G Motherboard
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
What cpu should i use
The Motherboard uses the AMD socket 939 so you should probably check out the AMD Athlon 64
Jun 17, 2010 | MSI K8N Neo4 Platinum PCI-E (NON SLI)...
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Apr 30, 2010 | Abit KN8 SLi Motherboard
Adding 2 gigs memory
try to install windows xP!! when the screen turns blue!! just press f7 until the setup is finnish!!
Jul 12, 2009 | Jetway 939GT4-SLI-G Motherboard
Help
It will be ok if you are going to be sure that the ordering part# correspond to this table: http://products.amd.com/en-us/downloads/AMD_Opteron_First_Generation_Reference_100707.pdf
Your motherboard maximum Front System Bus is 1000MHz.
Aug 17, 2008 | Jetway 939GT4-SLI-G Motherboard
Driver
Welcome To Jetway Home Page.. this company use nForece520LE(MCP65V)chipset motherboard and can not stall RAID disk driver in CD,for ... Example to JETWAY 939GT4- SLI-G mainboard.
You will find the driver on this link, Read follow instructions.
Good Luck, Please dont for get to Vote/Thank You.
Dec 26, 2007 | Jetway 939GT4-SLI-G Motherboard
New Jetway 939GT4-SLI-G won't power up
Try using the onboard video first, remove the video card and any other card from the motherboard. If it still does this, then check the memory, maybe the speed is not compatible. If it's not that then try booting up with the old cpu.
Apr 21, 2007 | Jetway 939GT4-SLI-G Motherboard
Computers & Internet Logo
391 people viewed this question
David Payne
David Payne
