Question about Jetway 939GT4-SLI-G Motherboard
Help will my socket 939 jetwat 939gt4-sli-g support a AMD Opteron X2 180 2.40GHz socket 939 cpu
    Scholar:
  • 155 Answers
It will be ok if you are going to be sure that the ordering part# correspond to this table: http://products.amd.com/en-us/downloads/AMD_Opteron_First_Generation_Reference_100707.pdf
Your motherboard maximum Front System Bus is 1000MHz.
Posted on Oct 01, 2008
I was wondering if my 939GT4SLI-G can run PCI Express 2.1 x16. Example of a video card would be, MSI R6950 Twin Frozr II OC Radeon HD. Thanks, Rob
This is your board:
http://www.dealtime.com/Jetway-JetWay-939GT4-SLI-G-Socket-939-NVIDIA-nForce4-SLI-ATX-AMD-Motherboard-Retail-939GT4-SLI-G-BRAND-NE/info?sb=1&tab=specs
This is the card you want:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127575&nm_mc=OTC-RSS&cm_mmc=OTC-RSS-_-Desktop%20Graphics%20%2f%20Video%20Cards-_-MSI-_-N82E16814127575
Some say that the card will work but with limited capacity. I don't see the power requirements for the card but, I would guess a minimum of 350w or greater. Your board definatley was not designed for this card. It's alot of money for a card that may not work at all with your system.
This is MSI's link:
http://us.msi.com/index.php?func=prodvgaspec&maincat_no=130&cat2_no=&cat3_no=&prod_no=2093#menu
There is a "contact us" link at the bottom of the page where you can try to ask them but, in my opinion, for the money, I don't recommend the card without upgrading your system.
Dave
Jul 01, 2011 | Jetway 939GT4-SLI-G Motherboard
How many graphics cards can you run on this motherboard ? also whats the maximum ram you can install on it ?
You may install 2 x PCI-Express X 16 slot, supports two PCI-Express interface Graphics cards with SLI mode and 4x1Gb Dual channel DDR400/ 333/ 266 -184pin RAMs onto your AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI Chipset 2000MT/s FSB Dual Channel DDR400 Socket 939 ATX motherboard.
Check out your motherboard's specifications through this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 09, 2011 | AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI...
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
What cpu should i use
The Motherboard uses the AMD socket 939 so you should probably check out the AMD Athlon 64
Jun 17, 2010 | MSI K8N Neo4 Platinum PCI-E (NON SLI)...
What is the fastest CPU I can run on an Abit KN8 SLI socket 939?
Your mobo rans in Athlon 64 socket 939 compatable processor. The fastest processor there is that you can install in this mobo is AMD Athlon64 4000+ Socket 939 Processor. =)
Apr 30, 2010 | Abit KN8 SLi Motherboard
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
What amd cpus does this mobo support? are there any that I can get off newegg for this mobo? and which sli connector should i get from Asus? like what length?
939 pin Athlon 64 X2 / Athlon 64 FX / Athlon 64 are the supported CPU's.
For the SLI connector, it's a 2 1/2 inch connector. (63.5mm).
Oct 26, 2009 | ASUS A8N-SLI Deluxe Motherboard
Can I use DDR2 800 MHz RAM on GA-K8NS-Ultra-939-Socket-939 MBoard
I don't think that that motherboard will accomodate the DDR800 you probably need a DDR333 or DDR400.
Calling the manufacturer support will render better information because they made the board. The memory you refer to may not fit the slot for this particular motherboard.
Aug 13, 2009 | Computers & Internet
Cpu and cpu cooler
Yep the cooler will work with your athlon processor.
~gnomer
Jan 31, 2009 | AMD Athlon 64 3500+ Processor (castle)...
Will it support it ?
Go to the manufacturer website of the motherboard you have. From the website you can look up the specs of the specific motherboard. It will list which CPUs that motherboard supports on the specs page.
Aug 17, 2008 | Computers & Internet
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
See all Jetway 939GT4-SLI-G Motherboard Questions
Jetway 939GT4-SLI-G Motherboard Logo
96 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Starnley Johnwells
Starnley Johnwells
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
