Question about Motorola Mobility RAZR V3
Troobleshooting When I close the lid on my Razr shuts off. Can you help me please??
  • picke Aug 25, 2008
    thank you lethatweapon for your solution. I will take it to a service center. Again thank you!!!
  • 50 Answers
The lever that closes ur phone lid is probably colliding with the internals of the turn off key. show it to a service centre......When it comes to phones, especially complex and expensive ones like urs, rule 1 is DON"T TAKE RISKS
Posted on Aug 18, 2008
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
Lid switch shorting somewhere. In this model there is no pin that I can ses. But after removing bezel it flickers but I need the location of the lid switch to check. When opening lid slowly it sometimes...
Probably not a lid switch related problem. In the more modern Toshiba's, the lid-close switch is generally located either above the keyboard area or underneath the front end of the palmrest (towards you), and the lid-close function is activated by a magnet located either above or below the screen. Best way to check if the lid-close function is working properly is to use Toshiba's power management to set the system to go to either stand-by or hibernation upon lid-close - and if the computer goes to stand-by or hibernation when you shut the lid, then that part is functioning properly.
A better, more detailed and precise description of the problem with the screen will probably help in addressing the real problem.
Sep 20, 2011 | Toshiba Satellite P205-S6237 Notebook
When I shut the lid to my acer 5315 it shuts off my wi fi adapter. I do not have the settings set to shut it off when closed.
try to got to your power management, there should be some options there when you close your LID to "do nothing"
Hope it helps!
Nim
Feb 14, 2010 | Acer Aspire 5315-2153 Notebook
My phone shuts off
Your turn off key is probably coinciding with the lever that closes the lid of ur phone.....show it to a service centre....
Aug 17, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Razor phone from att
disconnect when you shut the fone lid down is a call seting in the fone
Jun 19, 2008 | Motorola Mobility RAZR V3
Chest freezer lid
Vacuum is caused by contraction of air. If your temperatures are being maintained the difference in how easily the lid opens and closes is not a point to worry about. If the lid wont shut after it is opened you do have a problem. If the lid is staying open at one corner try, with the lid open give it a slight twist pulling on the corner that is not closing fully. This action should spring the lid back to its original sealing position.
Jun 12, 2008 | Freezers
Washer troobleshooting
will not empty??? TOP loading washer???? sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 12, 2008 | Washing Machines
Songs
Well moto razr v3i is not like v3 if u close the lid it will get close u can only use itunes will keeping the lid close.
Dec 30, 2007 | Motorola Mobility RAZR V3i Cellular Phone
RAZR V3M thinks it's always open - Screen will not turn off
in the top right corner you are suppose to have a little circular magnet that changes the screen when the phone is open or closed. I just changed my housing yesterday and took the magnet out and put it in my new housing but for some reason i have the same problem as you. so maybe you lost the magnet when you replaced the lcd and if that is the case then you are screwed. try have Motorola fix it, don't tell them you replaced the lcd
Dec 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
My Razr Isn't Aware that it is Closed
most flip phones, or flip anythings use magnets and sensors to detect if they're closed or not. Let's do a little experiment. Take a magnet. Now, run that magnet just above and right of the opened RAZR keypad. If your phone acts like it's been closed, then there's nothing wrong with the sensor. That's a GOOD thing. All that needs replacing is the magnet in the top part of the phone. It's located the bottom right of an open phone below the screen, right beside the camera on the inside. Replacing it is as simple as going to http://www.cnn.cn and ordering a new one. (you'll need a T7 driver to open the top part of the housing) If it doesn't shut off then the sensor itself is shot. As far as I know, there's no where on the net to get a replacement component for it.
Dec 14, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
