Question about Nortel T7316E 2-Line Corded Phone
Dialing out how do i dial out on this phone? Is there a button i must press before dialing?
    Scholar:
  • 108 Answers
Usually picking up the handset and dialing " 9 " will get you another dialtone and then you dial the number you want. If you receive a busy signal it could mean your system requires another number to dial out or your phone is restricted from dialing out. When you pick up your handset or press the INTERCOM key you should get a triangle shapped light which means you can proceed with dialing your access code for making a call ( 8 or 9 ). Hope this helps, let me know ...Mike
Posted on Aug 17, 2008
How to store and use numbers for automatic dialing
Press the STORE button, "Location?" appears in the dispaly screen, dial one of the digits 0 through 9 on the dialpad or press one of the 3 memory buttons:A, B, or C. Press the STORE button, enter the phone number using the dialpad, press the STORE button.
There are two ways to use the stored numbers. With the phone idle, press the DIAL button, press the memory button(A, B, or C) or one of the dialpad numbers 0 through 9, then lift the handset or press the speaker button and the stored number will be dialed. The other way is to first lift the handset or press the speaker button, press the DIAL button then choose the memory location by pressing one of the A, B, or C memory buttons or dial one of the digits 0 through 9 on the dial pad and the stored number will be dialed . I have included a link where you can download the manual.
http://www.home-electronics.net/USER-GUIDES/29369_DOM_ES_CD_IB.pdf
Mar 01, 2011 | Big Button GE 29369GE1 Speakerphone
With the Panasonic KX-T7633 - how do you change the time on the display?
Press Program button
Dial **1234
Dial 000
Press SP Phone Button Twice
Dial Hour (00-12)
Press FWD/DND button
Dial Minutes (00-59)
Press Auto Answer button to select AM or PM
Press Autodial/Store button
Press Hold button
Sep 28, 2010 | Panasonic KX-T7633 Corded Phone
How do I reset time and date
Which system do you have? Below are the Panasonic systems. Be sure you find yours.......
Panasonic XDP 824/1232
All programming is done at ext. 101
1) Press the program button, followed by *#1234
2) Dial 000, then follow the prompts on the LCD
KX-T308, KX-T616
  1. Use phone with intercom number 11. It will change the time for all phones.
  2. Keep handset down and press INTERCOM button.
  3. Dial 77.
  4. Dial the hour, with two digits (e.g. 03 for 3 o'clock).
  5. Dial the minutes, with two digits (e.g. 07 if it is now 7 minutes after the hour).
  6. Dial 0 for AM or 1 for PM.
  7. Press #.
  8. Press SP-PHONE
Panasonic KXT Series Telephone System
Setting the time must be completed from an LCD Display phone at Extension 11, using the telephone keypad. This system type requires "Easa-phone" series or a 7000 series model telephone (the model number is listed on the bottom of the phone) that has one or more small switches located at the rear of the phone. Digital "XDP" phones can not be used on this system type!
To set the time:
  • Lift the handset or press "SP-Phone" button on Extension 11.
  • Dial "77"
  • Enter the hour with 2 digits. (01 through 12)
  • Enter the minute with 2 digits. (00 through 59)
  • Dial (0) for AM or (1) for PM.
  • Press the "#"
  • Wait for confirmation tone. (Instantly after pressing the # button, new time counting will start).
KX-TA624
  1. Use phone with intercom number 101. It will change the time for all phones.
  2. Move MEMORY switch on rear from SET to PROGRAM.
  3. Dial *#1234
  4. Dial 000
  5. Press NEXT ("Sp-phone")
  6. Press Right Arrow ("FWD/DND") four times until you see the time displayed
  7. Change the hour with the keypad
  8. Press Right Arrow ("FWD/DND") to reach the minutes field
  9. Change minutes with the keypad, if necessary
  10. Press AUTO DIAL/STORE
  11. Press HOLD
  12. Move MEMORY switch on rear from PROGRAM to SET.
KX-TAW848
  2. Press PROGRAM (or PAUSE, if you don't have a PROGRAM button.)
  3. Dial programming access code (probably *#1234)
  4. Press NEXT (SP-PHONE, if you are not using the programming template).
  5. You'll see "Date & Time Set" on your phone's display
  6. Press STORE
  7. Press NEXT to see hours and minutes.
  8. Use your keypad to change the hour
  9. Press STORE.
  10. Press HOLD.
  11. Press PROGRAM
KX-T123211D
  1. Use phone with intercom number 101 (probably the receptionist's phone). It will change the time for all phones.
  2. Move MEMORY switch on back of that phone to PROGRAM.
  3. Keep handset down and press 0 on touch-tone dial.
  4. Dial year with two digits (e.g. 97 for 1997).
  5. Dial month with two digits (e.g. 01 for January).
  6. Dial date with two digits (e.g. 03 if today is the third day of the month).
  7. Dial day with one digit (1 for Monday, 2 for Tuesday, 3 for Wednesday, 4 for Thursday, 5 for Friday, 6 for Saturday, 0 for Sunday).
  8. Dial hour with two digits (i.e. 01 for 1 o'clock).
  9. Dial minutes with two digits (i.e. 07 for 7 minutes).
  10. Dial 0 for AM, or 1 for PM
  11. Press either AUTO DIAL/STORE or AUTO/MEMORY, depending on your phone.
  12. Move MEMORY switch on back of phone to SET.
Panasonic DBS 824, 40, 72 & 96
- From the Attendant's display phone.
  1. Press "On/Off"
  2. Press "Prog"
  3. Press " ##"
  4. Press "FF1 key"
  5. Dial 1#, 2#
  6. Dial the time in 24 hr format.
  7. Press #
  8. Press "On/Off"
- From any display phone in the system.
  1. Press "On/Off"
  2. #98 + Password
  3. Press "Prog"
  4. Press " ##"
  5. Press "FF1 key"
  6. Dial 1#, 2#
  7. Dial the time in 24 hr format.
  8. Press #
  9. Press "On/Off"
Panasonic DBS 576 & 576 HD
From any display phone in the system;
  1. Press On/Off
  2. Press "Prog"
  3. Press " * * "
  4. Dial the " Password"
  5. Press "FF8"
  6. Dial 81001
  7. Dial in new time in 24 hr format.
  8. Press Hold and then "On/Off"
Aug 19, 2010 | Panasonic KX-T7731 Corded Phone
How do you set the time on a panasonic kxt7731 proprietary telephone
Which system. See below. BUT make sure you find your system first....
KX-T308, KX-T616
  3. Dial 77.
  7. Press #.
  8. Press SP-PHONE
To set the time:
  • Dial "77"
  • Press the "#"
KX-TA624
  3. Dial *#1234
  4. Dial 000
  11. Press HOLD
KX-TAW848
  6. Press STORE
  9. Press STORE.
  10. Press HOLD.
  11. Press PROGRAM
KX-T123211D
  1. Press "On/Off"
  2. Press "Prog"
  3. Press " ##"
  4. Press "FF1 key"
  5. Dial 1#, 2#
  7. Press #
  8. Press "On/Off"
  1. Press "On/Off"
  2. #98 + Password
  3. Press "Prog"
  4. Press " ##"
  5. Press "FF1 key"
  6. Dial 1#, 2#
  8. Press #
  9. Press "On/Off"
  1. Press On/Off
  2. Press "Prog"
  3. Press " * * "
  5. Press "FF8"
  6. Dial 81001
Aug 15, 2010 | Panasonic KX-T7731 Corded Phone
How to program speed dial for various customers
1) To program a personal speed dial number, leave the handset on-hook. Press ALM/SD followed by the DSS button where you want to store the number. Dial the telephone number to save, up to 30 digits (press HOLD to insert a 3-second pause or MSG in insert a hookflash). Press ALM/SD to store the number.
2) To dial a speed dial number, select an outside line. Press the ALM/SD button. Dial the desired speed dial code 10-98 (system speed dial) OR press the desired speed dial button on your phone (personal speed dial).
3) System speed dial numbers may only be programmed by the system administrator.
Jun 02, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
I push the feature button it turns red as soon as i enter the phone number the light goes out press feature and does not program
Why are you pressing the feature button?
Press feature then answer. You envoked ringing line pick up.
Press feature then speed dial button, dial a number like your dialing out, then feature again. You've just set a speed dial button.
Press feature, then 3 and you've changed your ringtone on a series i phone.
Mar 16, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
How to program speed dial on sony spp-a946 cordless phone
  1. Press 'PGM'- "program" button.
  2. Press "speed dial" button.
  3. Select "station # " i.e. any button from 1-9 for speed dialing.
  4. (make sure to make a note of this selected # against the corresponding tel # and /or the person's name)
  5. Dial the complete (incl. 1 for USA or country code for other country tel. #s) telephone number to be stored for the selected speed dialing station #.
  6. Press "PGM" button again to complete the storing of the tel #.
  7. Test, after dial tone, by just pressing the selected station #
Mar 13, 2009 | Sony SPP A946 Cordless Phone
Program speed dial buttons
To program a speed dial for an outside line: Pick up the handset, press #00, press the button to be programmed, press *21, then enter the number to be dialed (including any dial out number and areacode).
To program a speaad dial for in internal extension: Pick up the handset, press #00, press the button to be programmed, press *22, then enter the ext to be dialed.
(Once you hit #00, you can also follow the screen prompts).
Jan 21, 2009 | Avaya 4412D Corded Phone
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
STORING A NUMBER IN MEMORY
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
CHANGING A STORED NUMBER
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Nortel T7316E 2-Line Corded Phone Logo
526 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
